Root [ROM] unSENSEable V2.1 |3D|Fast|Lite|Great Battery| Now Overclocking|Buttered Toast| 04/11/13 |
I've had Android phones for years. Never rooted a single one. I couldn't justify the hassle if my phone did "everything" I wanted it to do already... What a fool I've been. I decided to take the plunge and mod my V, and chose this ROM to experiment. I've certainly caught "root-fever", but honestly don't think I'll be flashing anything else to this phone. This ROM is PERFECT for me...
Wow. That's quite a statement. Thank you. That makes me happy.
Made it a day before getting stuck in a random boot loop cycle. I rebooted for some reason and then the phone would reboot like every few minutes. On a fresh wipe without reinstalling apps to see if that's the problem
Try turning the max speed down to 1512
One question, and forgive the fact that I don't know much about all of this... I rooted, s-off-ed, did the Jbear deal... MMS works fine and voice/data are acceptable (my phone IS used 80% of the time on WiFi though) but what advantages will I gain with OTA, different radios, and/or hboots? Reverting to stock, updating stuff, and reflashing is not hard... But that means being that long without my baby in my hands...
Actually a great question. In my opinion. The OTA updates provide quicker texting and more reliable signal. Again this is my opinion. Most others feel the same.
You can actually flash the RUU right thru the bootloader. It's pretty easy. . then take both. OTA updates. Update profile/prl......
Then flash a recovery. I like to do this from the bootloader as well. Then I flash a ROM thru recovery. Then flash new jbear 1.5.HBOOT. Thru bootloader.
Again this is my opinion but I do recommend doing this if you haven't already done so
I updated to V2.0 from 1.4 Did full format (all but SD) then wipe cache and dalvik. Using 4ext.
Installed Kernel Tuner. Can't seem to turn on CPU1. When I go to adjust the settings it only shows min & max for 1 cpu. Tried an older version of KT with same results.
Doesn't run very smooth. Don't really need to run at 1500mhz. Would rather have longer battery life.
Signal strength seems lower.
I haven't done the March OTA. To lazy to do all the RUU, Lock, unlock, wire trick, etc again. (just got tired thinking about it.)
Just to add some interest. With KT my Antutu scores were 3500. After uninstalling KT and rebooting phone, I'm hitting 9297! Of course the CPU are running at 1728!!! Would really like to have them at 1188.
Im not having any issues turning cpu1 on. i just hit the button in kernel tuner and it turns on. Try updating the app. not using older version. and believe it or not the battery life is better. WAY BETTER. Even overclocked
if you run the RUU. IT BRINGS YOU BACK TO STOCK, BUT YOU REMAIN S-OFF. read previous posts . you will see how easy it is to flash RUU. then reroot. 1 HR MAYBE... If your slow
All right guys. This app is being deleted from future releases. I'm so frustrated with it I almost want to push a update just with the removal of this application.
No offense to the development team but the constant updates are killing me. Not only that but it keeps showing me 1 core in my CPU settings. I deleted it and I suggest you do the same. I recommend system tuner. I have the pro version. It's worth a few $
Here's the odd thing, I switched to midnight rom s and my sms and mms messages all work now. I like your rom overall more, it looks and feels more like stock ICS, but text messaging doesn't work for me.
Well. You seem to be the only person with texting issues
Apparently so, I love your rom too. I've tried many others and like your's the most, but every time I try and text I get error code 2331. I have done everything though, RUU updates, made sure I wiped everything before this install too.
I agree. System tuner is better! Kernel Tuner has been messed up thanks to numerous updates that broke it.
I tried Kernel Tuner a few times and every time I didn't give the results I expected..... Its available in the Playstore and on XDA so I see no point in adding it to Roms
I agree. I added it because I loved it and felt it gave the user a lot of control. Waaaaaaaay to many updates. And glitches.
And off topic. Nice GB ROM Mobz
Yeah its pretty nice i kinda missed that CRT animation and i didn't wanna lose 3D for it but i still have to find out why it bootloops after a reboot........ maybe you could take a look at it?
