nsciucco
Android Expert
any further suggestions butthead. lol
love the monty meme tho.
Hmmmmmmm.
Use 4Ext recovery.
Wipe all partitions (except SD card)
Wipe dalvik .
Then flash.
Enjoy Brother
Thanks Mobz.
Oh BTW still haven't had anytime to flash that ROM and check it out. Will do soon.
oh, one more thing. what about the 2nd cpu problems...where they fixed in the update?
and if soo, how do i access those functions on my own?
That stinks. There go the woes of developing. What was the issue.
Oh. I don't care about being of topic
None IMO S-Off is where you get benefits
How would i rate this ROM or thread 5 stars?? I like it but i don't know how to rate.....
 Jk but just put 5 stars!^^^this!
There is no benefit of being s-on. The reason you see so many s-on users, is because the wire trick can seem daunting. Some people just don't want to do it. But all the benefits come from s-off. You will save yourself many headaches if you go s-off!![]()
Unless I'm missing something, you shouldn't need to do anything special that I know of. As far as I know, you should just be able to wipe all partitions (except sd card) and then flash the new rom.
i must say, i am somewhat disappointed with how many functions do not work in this rom....after extensive testing.
here's a list. leedroid's tweaks = garbage. the tweaks it tries to set make the android UI force close repeatedly forceing either a recovery restore, or a revert to the other tweaks setting sense stock...which messes up this rom settings anyway. i highly suggest dumping this apk, or adding to or changing this apk.
the "extra settings" in the settings menu....none of them work for anything that i can see....not the reordering or anything. battery text and all sub-menu's do nothing. clock and all sub-menus do nothing. toggles and all sub-menus do nothing. they claim to do thing, I change the settings thru these menu's and nothing happens.
How did no-one notice these problems? the over clocked kernel how-ever works flawlessly. the only problem is getting the cpu0 and cpu1 to both stick on after reboot, which sadly does not. reverts to only cpu0.
