Root [ROM] unSENSEable V2.1 |3D|Fast|Lite|Great Battery| Now Overclocking|Buttered Toast| 04/11/13 |
Nsciucco, be proud.
I left it on but didn't touch it and yet it still lives.
Nsciucco, be proud.
That's pretty amazing. Though my battery can't really last a long time if I have 3g on and use my phone for a while. I can say it lasts maybe like 4 to 5 hours on a daily basis depending on what I do. Could be my System Tuner settings as I don't really mess with that stuff.
I'm having issues with both 2.0 and 2.1 getting notifications for my calendar alerts, it worked fine on prior builds but now nothing is giving me an alert.
I have it so my work schedule gives off a 15 minute reminder. The alert does not even show up in the notification... Anyone else experiencing this?
Great ROM. Having issues with facebook and navigation. Facebook when chatting with someone and closing facebook the icon of the person you chatting with stays in the screen, first I see this with any rom. Navigation still loosing the signal once in a while.
I use google calendar all the time. NO issues for me
I dont use facebook.I cant help you there.(Is anyone else having that issue ?)
Navigation is not a issue for me . You have to have a good data conection to get a GPS lock. Once it locks the data connection dont matter . You may have just been in a bad area.
Hey can anybody help me out with a problem?
I am trying to run the RUU via bootloader on a unlocked (s-on) phone. This is not my phone though, as i prefer s-off. Also it has H-Boot 1.57 but when i put the zip in root of sd card, it keeps saying wrong or no image and won't load it.
Just thought I'd chime in and say that I got the same bootloop problem with the new version forcing a format and reinstall. I was using kernel tuner so maybe thats the issue. I was just changing the frequency though.
I deleted the app for a reason. I haven't had any issues like that. Even on previous version (2.0 )with kernel tuner. All that being said. I would like to see if you still have that issue without using kernel tuner. I doubt you will
Also what speeds and governors did you set that resulted in bootloops?
I've been using this ROM for 6 days now. At one point it was nearly unusable for how slow it became... typing was excruciating. Even the boot up animation was in slow-mo. I only had 48 total apps, but after removing 7 or 8 that I suspected the most & rebooting, it was incredibly fast again. I'm happy with my current app selection now (at 43 total) but I find that it starts slowly losing speed over the course of a day's usage. On the stock ROM, rooted, and loaded with about 80 apps, I never needed a reboot for this reason. I think this ROM is worth a quick reboot each morning to keep things fresh & snappy. But I'm wondering if it's just me or if anyone else on this ROM has noticed the same thing? (in other words, I wanna know if I should hunt down the offending app and replace it with something better behaved)
One more thing. I can't get Google+ to open on this ROM. Is anyone else having that problem? Not sure if it's just my particular setup that's failing or a bug in the ROM. Thanks.
Me either. Though I think it was good before when I first flashed the ROM. Haven't gotten it to work yet :/.
So I just installed the FM radio apk... It "works" (finds local stations, shows ID text, makes good presets) but I can't get any audio? After looking at my friend's 100% stock Sprint version phone, I noticed when his radio is running and he uses the volume buttons the screen shows "FM Radio volume" and not "media volume".... So is there an easy way to add this function?
Just did the same thing, anyone have ant ideas?
this has nothing to do with anything but just wondering does anyone know if its possible to add long press back to kill current app on this rom. I really like this rom but i miss the long press back.
