Atma
Extreme Android User
My video camera is working just fine with the 01022012 build. My wife
Strange, it was definitely borked on more than just my phone, does it say 20120102 in the Build ID under About phone in Settings? I didn't even realize it till it was posted by thekraven in another forum. I even know which part of the code was borked, and have fixed it just now, will be posting an updated build soon as testing is complete.![]()
Just flashed 1.03 and my uot theme. It seems that the notification dropdown background on default, overrides my theme. So instead of being 50% transparent like I set on my theme it is opaque. But with the color changer option now, u can just set it to black at 50percent and after boot it looks like it should
Strange, but as they say, if it aint broke, don't fix it.Build ID eng.jerryscript.20120102-152500
That is...beyond awesome!@brotherswing: I have something your geek-side will appreciate in the next build, network adb built in to settings menu. I hate wires!![]()
Same here.
The default wallpaper is built in to /system/framework/framework-res. apk and as far as I know there is no easy way to get it back once changed. The only way I can do it is to set sdcard image as wallpaper, delete it from the sdcard, change something in the framework-res.apk, recompile and replace the original framework-res.apk.
BTW anyone got the 2-way call recording working with the new kernel? Mine doesn't after regular ROM update. Maybe I have to do clean ROM install with full wipe?
hi, sorry im new here and just flashed the newest build. how do i get the live wallpaper that's in the screenshots in the op? also, i changed my wallpaper and now i can't seem to find the default wallpaper anywhere, is there a way to get it back?
i found the default wallpaper.Same here.
i couldn't find it there.That's the one I was talking about in the Cyanogen wallpapers.
Funny, my spell check keeps trying to change Cyanogen to cyanide!
Did you download one of the call recording apps from the market?
i couldn't find it there.![]()
