brotherswing
Android Expert
@Jerry - That's what I did, it pairs but the keyboard doesn't seem to do anything. Do you have to select it in the settings like switching from SwiftKey to Swype? Or do you use an app like blueinput?
I don't know if anyone else has this problem, but since I've started using CM7 I can't put my phone to sleep and continue to listen to music. When I put the phone to sleep it completely stops the song and reverts the playback slider to 0:00. If I go to my launcher before I put the phone to sleep, the music continues playing - it only does it when the music app is open.
Can somebody look into this?
Have you tried installing any other apps?
have you rebooted your phone?
Since it's a problem with the market, I would try reflashing gapps next.
First, go into manage applications and clear market cache, then clear market data.
Then, reboot into recovery, wipe cache, and under advanced wipe dalvik cache.
Then, reflash gapps zip file.
Reboot, sign in, and try installing an app.
When I reboot into recovery it reads "- wipe cache partition" is that 'wipe cache'?
UPDATE: Went for it 'wiped cache partition'
FYI - I found the wipe dalvik cache okay under advanced as noted.
UPDATE: Followed all steps and still same problem. I used the link at top of post and downloaded the GAPPS for CyanogenMod 7. Maybe that's not the right GAPPS?
What exactly is the text of the error message?
How many apps do you currently have installed?
Do you use any *2sd scripts, link2sd, apps2sd, etc?
Hi All,
I'm having a couple of problems. I am on the 12072011 build. I am trying to install Google Music. The error message I get while installing via the Market says "already installed".
I have tried JerryScript's post regarding renaming music.apk. I also cleared the music cache and data as well as system and dalvik cache. Is there something I am missing?
Second issue: I have a 8Gb card installed and most of my apps are installed there using CM7. I have 5.7Gb available on the SD card and 86.84Mb available internally. I tried to update some apps via the Market and was told that there was not enough room.
Update: I found a solution for the second issue in another thread. My main issue is trying to get Google Music installed.
could you point me to the solution for your second issue? I have been having the same problem. I've tried deleting the market cache/data, deleting the 01mdalvik file, wipe cache/dalvik, as well as the Titanium Backup Dalvik integration. The Titanium Backup solution worked a while back, but has since quit working (for me).
Thanks!
From Michael323:
I was getting the 'insufficient space' error from the market consistently when downloading apps greater than 2-3 MB or so.
I found a thread on forum.cyanogenmod.com - post #6 by capeli provides the following terminal command:
# cd /cache
# mv download download.old
# mkdir -p /sdcard/cache/download
# ln -s /sdcard/cache/download download
The thread is for an HTC phone but so far it has cleared up the problem for me. It sets up a symbolic link that uses the sd card for caching downloads. Seems pretty simple and brilliant to me. All credit goes to capeli.
Those are the commands that I used. The article didn't say to use SU but I figured that anything like that would need the SU command.
Sounds like a bad one, being so cheap, it's not surprising, meh.![]()
I'm a noobie, so here goes...
I used gingerbreak v1.20 to root and all is fine. I follwed instructions to the T and flashed the ROM BACKside-IHO-VM670-01102012.zip and then GreenMachineTheme-01102012.zip. Phone boots up great and all seems fine until I try to set up the account for market. Then the problem starts, it says it can't link with gmail. I finally changed to CM7.2RC0-VM670-BobZhome-010112.zip along with gapps-gb-20110613-BobZhome-v2.zip and it works fine. I do prefer the interface of the first two, so how do I make it work? Also, when changing gapps, how is that done? I've been reading a lot of posts and am getting into info overload, so now I am asking.
Thanks,
Gerald
Is there a trick to charging the phone when it's powered off ? I think I am missing something. I've tried booting into recovery but the screen stays on and I have no indication that the phone is actually charging. I have the latest build of IHO inastalled and running smoothly. What did I miss ??
By the way, what is GreenMachineTheme-01102012.zip?
Thanks,
Gerald
