)adb connect 192.168.1.123:5555
Which is why I have a car charger. It goes on it when needed.However, turning off Wifi defeats the purpose of having a notification that tells you Wifi is available. So it does go without saying that WiFi is searching hehe. It's merely an option for those who didn't know it was there and wish to use it. I probably could of worded my post better, too.
New build is up:
BACKside-IHO-VM670-01092012.zip
md5sum c149c3a2b198cb5de96b84abd572d390
GreenMachineTheme-01092012.zip
Changes:
-Made some changes to status bar and notification dropdown background settings to impove theme support (needs testing)
-Added custom notification dropdown background image, please submit additional ones to add in future builds, selection will be based on popularity (donaters to Blarf will of course be given preference)
-Add option to make media the default volume control, default is still ringer volume, helps when trying to set a song's volume before you begin playing it (embarassment saver)
-Added ADB Over Network option to Settings>>Applications>>Development
Once enabled, go to Settings>>Wireless and network settings>>WiFi settings then press your menu key and select Advanced
Use the IP address listed and add port 5000 to use ADB via WiFi
(replace IP address with your phone's)Code:adb connect 192.168.1.123:5555
As always, thanks to Blarf, BobZhome, mrg666, LeslieAnn, kermikalelite, Whyzor, bigsupersquid, the CM team, the AOSP team, and many many more!![]()
I just flashed the new build and I'm wondering if anyone else is seeing a transparent status bar when they press any of the soft keys to turn on the screen, and then see the status bar become normal after unlocking the phone?
Thanks for the heads up, edited the OP to correct the md5.I've downloaded the new build using my phone three times and all three times I got this md5 sum c149c3a2b198cb5de96b84abd572d390 .
Edit: noticed your post with the correct md5 sum ^.
The first post says this: md5 checksum 9c69ad42485319a31835810b9d1bb6c1
Thought the download site was messed up again.
Yeah, I haven't figured out how to apply the changes dynamically yet:Yes, I do but it doesn't become normal. The bar is transparent no matter what setting I choose in status Bar Tweaks. Even if I try to change to different color.
*Edit* I got it to change but I have to reboot every time to change it. I don't remember having to reboot with the last build?
Settings--CyanogenMod settings--Interface--Statub bar tweaks--Status Bar Appearance said:Theme, ROM, transparent, or user
defined color. Reboot required.
Is the image the little android guy like in green machine?
Changing the images on your own is easy. Extract SystemUI.apk, open as archive and replace status_bar_special.png in /res/drawable-mdpi, push back to phone and reboot. Or follow a UOT Kitchen's zip file as a template for making a flashable zip file.How hard would it be to add an image picker so we the users could set our own images? Another crazy thought, if I knew the path, could I place an image in a flashable zip (signed, of course) to set my own? I'm thinking about the theming possibilities.
Yes it is, good eyes. I am accepting ideas for other images to include in future builds. Post some images, but realize I don't want to add too many, size does matter when it comes to our phones.![]()
Yeah, I have been noticing my phone has been acting pretty poopy. I thought maybe it was everything getting cached. I've rebooted 4 times so far, 2-3 more than normal after a flash.Phone has been freezing up more than usual. Especially the launcher and mostly in the gallery. Not used to that happening.
Give it a couple of reboots, and don't do anything to it after it boots up for at least 10 minutes. If that doesn't work, wipe and reflash.Phone has been freezing up more than usual. Especially the launcher and mostly in the gallery. Not used to that happening.
Special Build Is Up!
BIG THANKS TO Tom Marshal aka tdm FOR FIXING THE CHARGE-WHILE-POWERED-OFF ISSUE!
BACKside-IHO-VM670-01102012.zip
md5sum 8070234dcf9bad2ea7f96666b2857418
GreenMachineTheme-01102012.zip
Changes:
--Reversed logic on transparent status bar background for theme/rom, needs testing.
--FIXED CHARGING WHILE POWERED OFF
notes:
-Turning off your phone and then plugging it in will begin charging
-Long press the power button to boot the phone up
-Rebooting in recovery while usb is plugged in will put you in charge-while-powered-off mode, once you see the battery charging images, long press the power button to boot up.
Thanks again Tom, this is one of the oldest gingerbread bugs around for the OV!
Note- I will not be adding this to the main post or the wiki yet, since I just posted a build.
Changes 01092012: Made some changes to status bar and notification dropdown background settings to impove theme support (needs testing) -Added custom notification dropdown background image, please submit additional ones to add in future builds, selection will be based on popularity (donaters to Blarf will of course be given preference) -Add option to make media the default volume control, default is still ringer volume, helps when trying to set a song's volume before you begin playing it (embarassment saver
) -Added ADB Over Network option to Settings>>Applications>>Development. Once enabled, go to Settings>>Wireless and network settings>>WiFi settings then press your menu key and select Advanced. Use the IP address listed and add port 5000 to use ADB via WiFi, ie: adb connect 192.168.1.123:5555 (replace IP address with your phone's)
