JerryScript
Android Expert
If you are running the 01102012 build, then you just turn off your phone and plug it in. Or you can plug it in and then turn off your phone. Either way, it should boot into charging mode, where you will see a greyish background with a large battery icon that has a charging animation.Is there a trick to charging the phone when it's powered off ? I think I am missing something. I've tried booting into recovery but the screen stays on and I have no indication that the phone is actually charging. I have the latest build of IHO inastalled and running smoothly. What did I miss ??
To power up your phone while it is charging this way, long press your power button.
