Not a whole lot of difference really. I've been concentrating on the os while BobZhome has done some awesome work on the kernel. If you pull his git, look for the chaos config file, that's the one he uses to build for the OV.Hey Jerry, how comparable to compiling a kernel for linux is it? I've always cooked up custom kernels for Slackware, and wondered how different it is for Android?
I had a typo in the manifest, it's fixed now so everyone else should be able to see the update via the BacksideUpdater. Still working the kinks out of the manifest.For some reason my updater can't seem to find this one. I'll d/l from mediafire.
Bob saw your posts about the issues with the keyboard, went back through his sauce and realized he left HID out sometime in the past month or so. He added it back in, so hopefully you won't have issues anymore!Bluetooth hid support? I thought that was already present. Maybe I won't need Bluekeyboard JP anymore... Will test and post results later.
I had to disconnect, unpair, and check/uncheck every option. Then I scanned, long pressed the menu item for the keyboard, then as soon as I choose pair, I fast click the menu again before it says disconnected again. Then I'm able to enter 1234 in the phone and on the keyboard. Give it a moment, and it's working fine.I lied. Just flashed it, runs very smooth. Love the egg, you rock! I'll keep you posted on the keyboard.
Was auto restore settings in the options set?
New build is working flawlessly so far, boot animation changer is working, updater worked perfectly, very smooth and responsive, so far no errors to report. Keep up the good work!
I would guess then using the Metamorph app to theme is what borked the changer for me. Again, no biggy.![]()
That's always a possibility, are you making sure that when you are trying to change the boot animation, that you're choosing a bootanimation.zip file?
