JerryScript
Android Expert
The bootanimation changer requires the default file manager as well.
So does the manual selection option in the updater.
When the file manager opens, click the home icon to switch to the root of the file system, then you can select system/media.Great new build, thanks! btw, got the usb storage to work, thanks.
For some reason i can't find the system/media folder to choose an animation, anyone know if it should be in the root of the sd card, or inside another folder?
You should be able to in the kitchen. Look under the popup tab, there should be text color options.
I have the same problem as Omensedge, when I use the status bar to adjust the brightness, it works when it wants to. Which isn't often.
Yeah, I was swiping. Thanks for the info. To many convenient gui's for theme elements and you'll make us themers obsolete!
Hmm, I think there needs to be an app for that, if there isn't already.Unless he makes an option to export the theme changes on the phone, for others to use that are too lazy, so it would be like having the kitchen built into your phone.![]()
If you are referring to selecting it to be used with my mods, not very, the file manager needs to follow the open intents, so that I can access the appropriate intent in an action with request call. I could write code that checked for every known intent of every known file manager, but you know I won't be doing that.How feasible is an option to select your preferred file manager?
Oh, by the way, the bluetooth keyboard doesn't work with the new kernel at all. I officially give up on that.
After I pair it, I just use it, I don't have to use any third party apps. Have you tried it without any BT apps?I kind of figured. That's not a big deal, though. As for the keyboard, yes, that's the only way I got it to pair. The thing is, after pairing it just doesn't seem to do anything. BlueKeyboard JP doesn't work now, and even though it shows as a connected HID device it doesn't show up as an input method. I know some members have been following my little bt keyboard saga. I think the keyboard I ordered must be very different from yours, as I've never been able to recreate your results. I can't find the name of the manufacturer anywhere, and support is nonexistent. So the moral of the story here is don't buy cheap Chinese electronics if you expect reliability.
That's kinda built in, in a round-about sorta way. Press the I've Already Downloaded button, select the old version, and when it comes up as a bad md5 match, select delete. When the download page opens, just press back.Downloaded and installed latest. Would it be possible for the app to delete previous versions in the download folder? As an option even?
