Sounds like a bad flash. Did you verify the md5 checksum?
Will look into it, but I do not now, nor will I ever use FB, so users will have to test.![]()
Try another theme. It's white in Quicksilver.
hmmm, let's see if anyone notices![]()
Yeah, I'm looking into adding an option for push notifications, so long as I can do it without wasting battery.If you and Atmazz hadn't made those posts I would never notice unless I constantly checked BACKside updater. I know I'm addicted to flashing but even I won't do that... yet
That function is planned for future updates.This was my very first update through the update function.
I guess I was under the assumption that the updater downloaded the green machine theme as well, and I was wrong.
Is there any way to add that function Jerry?
Yes, but what's the point of having 100mb of unusable space?It's nice to be able to update my apps finally but my available internal space has diminished from 100 mb to 23 mb
Now with 01mvdalvik functionality removed,
What used to happen is the 01mvdalvik script would move the dalvik cache to the same partition your market downloads would go to. This made it appear you had lots of extra space since dalvik cache was moved, but the Market would check the download folder for space, and since dalvik was in that partition, the Market wouldn't allow you to download/update and gave an insufficient space error.
Now with 01mvdalvik functionality removed, the dalvik-cache files stay in their normal directory, which is your internal space is taken up. You can use TB's integrate dalvik to system function to fix this, just be sure to undo it before you install another ROM or you'll have to reflash gapps.
You can also use any of the *2sd scripts, but I do not support them, too many issues with so many different versions.
