Looks like tethering is an acceptable topic to discuss now.
While AF can make it's rules to suit it's needs, that doesn't change the fact tethering on the OV is againt the TOS. The ability is built into IHO, but that's as far as we go.
I believe data is data, but I don't make the rules.![]()
I have been doing some experimenting, but I'm limited to using various headsets (mic and non-mic) to test with since I don't have a Square.Hey Jerry,
Anything happening on being able to use the Square app? I've read the last several days postings and didn't see anything. Still would like to be able to use your fine work on the BACKside ROM (hint hint).
Thanks,
Gerald
There's a report of one of the other hardware accessories like Square (can't remember it's name right now) having the same issues, but only since we made a change to enable two-way recording on phone calls on Jan 2.
If you have the time to try a previous build, would you let me know if that change made any difference? Here's the latest build before the change:
BACKside-IHO-VM670-12212011.zip
The issue is that without LG's source, and complete schematics, it's almost impossible to determine the gpio that gets called when various types of plugs are used.![]()
Quick question though, usb mass storage doesn't work?
You better clean up your act soldier. Just what kind of unit do you think we operate around here. It's been three days since the latest release, and you are still back in the dark ages? Next time this happens, you are going on report!I haven't even had a chance to flash the current build. I need to get on top of things. I'm starting to get the shakes.![]()
Hi my name is AndyOpie150 and I'm a ROM flashing addict.I want to try out the backside ROM it sounds very smooth?![]()
