Start with your min at 480 and leave it there, you wont find better results with a lower min speed, in fact lower can cause battery issues.
For max, start with a number around 800, but DO NO SET ON BOOT YET! Once set, open the gallery, then try playing something like angry birds (any 3d game will do), then try to take picture with your camera. If at any point, your phone freezes or reboots, lower the max down a notch and test again. Once you find the number you don't have issue at, lower it one more notch for safety, then check Set On Boot.
Some people can overclock above 800, my phone is only stable at 749, ymmv.
Overclocking will make almost everything run a bit faster and smoother, once you find that magic number.![]()
I had been up there, but settled back on 806. The extra few clock cycles don't make a huge difference once you start getting over 800 MHz. The performance limitation at that point is more the processor's architecture. You are also draining the battery faster by generating more heat. I think Angry Birds runs just as smooth at 806 as it does at 844 or above. Assuming your phone can run that high.![]()
using 2012-01-09 build. The clock on the status bar did not update with the change to daylight savings time. The clock on the lock screen did update as normal. Any suggestions?
For cammykool, this weeks update to BacksideUpdater will include an extended manifest, allowing you to install older versions of BACKside-IHO!
If I get the bug worked out in time, you will also be able to install a recovery via BacksideUpdater!
(edit, looking good)
Might be an easter egg or two in there as well.
For benslgdroid, improved functionality of the status bar restart service. It's still not perfect, but it should work a bit better!
And if I have the time, you'll be able to long-press the dropdown background and select the image there rather than going through settings.![]()
I had to reboot my phone to get the time to update.
@Jerry - Could the updater also handle themes?
Settings>> Cyanogenmod settings>> interface>> status bar tweaks>> set to Rom![]()
