brotherswing
Android Expert
Just updated to 0306, seems to run fine. I did have to reflash gapps again, which was odd. CWMT works just dandy with it.
MMS should work fine, I test it before releasing each build.I recently installed the February 29 build on my phone. Everything looks great, but I am having a problem with MMS. Text messages work fine, but I can't send or receive MMS. Has anyone experienced this too?
Also, I have a problem with the SD card that came with my phone. If I do a software reboot the card doesn't seem to mount. It only seems to mount if I fully shutdown and then power up. Is this normal?
Thanks to all for the all time and effort put into development and support.
Some have had luck clearing the MMS and Telephony caches, ymmv.Thanks Jerry. Any pointers on how I can resolve my MMS issue? Messanger hangs on sending...
... I think the 'Skip on security' function may be partially broken--under Settings > CyanogenMod settings > Lockscreen > Unlock options. I've always had this option checked/selected, and the setting would be retained and functional after the last several updates. However, in this latest 0229 update, the function no longer seem to work after a reboot--the Sliding Tab lockscreen appears even though disabled. ...
[Edit] Besides upon reboot, the Sliding Tab lockscreen also appears unexpectedly when the charger is first connected. [/Edit]
[Edit #2] The Sliding Tab lockscreen also appears when pressing the Power, Home, Return or Search button to wake the phone. However, pressing the Menu button to wake the phone behaves as it should--the keyboard for unlock PIN entry screen appears and no Sliding Tab screen. [/Edit #2]
Hope this fixes the double lockscreen I'm having with the 02292012 build. (Not able to turn the CyanogenMod one off)
Google just rolled out an update to market, It is now "Play Store" in your launcher. After the update the old "Market" shortcut will do nothing. For a while there I thought something was broken. If this happens to you, it was not Jerry who did it.
He's right about the dead market link and the changing to Play Store app..
Yeah, it changed to the play store but the Market link works, at least for me it does..
I'm running the 1-31 build.
And you're right about that too cause I just chickened out and went back to 1/31, seemed a little quicker, market link still works?
Thank you guys!
The rom is absolutely incredible. Great performance with incredible battery life. I like this phone on backside IHO better than my evo on stock rom. I've had some issues with some minor bugs but I'm sure you guys will work them out. I will drop you a pm if they persist in future builds. As far as working as a phone for what I need it for it's been flawless with calls, text, and mms. I'm running launcher pro and swype beta. I Couldn't be more pleased. Did I mention the great performance and incredible battery life? And lots of eye candy too. Damn. lol. Thanks again for all the hard work guys. It's very appreciated.
I've been lurking here for a few days and decided to install this latest ROM to replace the stock Virgin Mobile ROM. Do I need the GAPPS flash zip, as indicated in the first post / ROM release? If so, where do I get it? Thanks!
BTW - Does this ROM include Flash?
It supports flash if I remember right.No, try the Dolphin HD browser from the market .. oops .. I mean Google Play.It supports flash if I remember right.
