I've been using the BACKside ROM since mid January and really like the performance of the ROM.
This last build 03132012 is really running best of any so far.
I did not give the wife much of a choice in flashing her phone with the 03132012 build and making her phone more custom to her with the following theme:
Pretty-N-Pink
Is there a was to change the color of the box where the phone number you are dialing is typed out? It is dark gray and once you start to enter a number, it turns green. The only option I see where you mention is the digits color and that only changed the color of the digit inside the box.
Another question can the number pad color be changed?
Thanks for your hard work on the BACKside ROM. Have a donate button anywhere?
