rooter1
I concur!Why not stick with the tried and true VM670NH recovery?
If you have a new screen if you reboot into recovery you will get the infamous black screen which is why many people are so anti Rom manager.
Don't mean to contradict you ben but it is in fact the proper Touch Screen Recovery. I don't know how he managed to install it. I haven't been able to get ROM Manager to download it to my V and I have the premium version
The recovery that's the problem is the 3.2.0.1 in the Flash Recovery option.
The Touch screen Recovery is a separate recovery download option on the premium version (paid)
Don't worry a5pe4 it's a very good recovery. You just can't flash a radio.img from it. Something you don't need to worry about if you didnt install the firmware update.
That's a known bug in the current build. You don't need to pull the battery, the lockscreen functions, you just can't see it. Swipe your finger like normal, then rotate the phone's orientation to landscape and back. You should be unlocked and looking at your perfectly normal homescreen.
That bug should be fixed in the latest build. Be sure you are on the 03132012 build.![]()
I can not help you out, but may be able to suggest an app that might work for you; VlingoI can attach my phone to my car radio via bluetooth and make phone calls. I would typically push a button and say "Call John Smith on Mobile" and it would make the call for me. The call would go through and it would say "Active Call: John Smith" on my car radio.
After putting this ROM on my phone, I am no longer able to do that. It's as if the radio is not getting my address book download. I can no longer make a call by saying the persons name and it not longer displays the persons name on my radio. Now it simply displays the phone number ("Active Call: 555-555-1212").
Is this a known issue?
