That would be your problem. Just get the proper one then flash it.
That did the trick.
Thanks for the tip
Anyone else having the phone get hot during charging since the update
Not with mine. I notice no difference in temp with or without it plugged in.
You obviously added cooling!
Sent from my LG-VM670 using Tapatalk 2 Beta-4
Try rebooting, then pull the battery hold the power for fifteen seconds replace battery and boot, finally you can try a full wipe that worked for me when it got stuck in headset mood.
Well if I do a full wipe I have to re-root my phone entirely right? I'm really not in the mood.
Nope no re-rooting. Just reflashing.
Restore your nandroid of your stock and test it there. If you have a problem in the stock it is probably a hardware issue.Just did a re-flash with wiping literally everything and it still does it.
Technically it won't make a difference. Essentially it will do the same as installing the ROM, with wiping the cache's and everything. Chances are it's a hardware issue and I will un-root it and send it to Virgin Mobile to try to fix it or replace it.
If it's a software issue it would. If it's a hardware issue it wouldn't
My phone seems to have no sound when I make calls. I can get sound out of my speaker phone during my calls but during my calls the main ear speaker no longer works. Is there a fix for this?
How would you expect that? There's really nothing in this ROM that would conflict and disable that speaker.
If you really think it's a hardware issue then make sure it's a hardware issue. Try downloading and installing the stock nandroid that you made. If you have no stock ROM to restore, download and install a stock ROM. If you still have problems with sound then it's a hardware issue. If it fixes the problem then you probably got a corrupt download of the BACKside ROM (this is why I always check the md5 sum after downloading). This can be caused by a slow connection, using 3G instead of WiFi to download, and or, a messed up server.
If I could bother you guys for a wee bit of help. Id appreciate it much! I seem to be having an issue getting the screen timeout set properly for the lockscreen.
CyanogenMod settings - Lockscreen - Delay and timeout - Screen timeout delay: I set this to 30 min to test.
The lockscreen still shuts off in 5 seconds... barely enough time for my old eyes to adjust to see what time it is lol.
Am I in the wrong setting?
Edit: Forgot to mention that I am using the latest BACKside release.
Under the main menu then display there's a section for screen time out, make sure that's set to a higher value as well as in cyogen settings.
I use Widget locker.
I have all timeouts I found set to 2 minutes. It will still shut down after about 5 seconds like you have noticed.
I found that out since I use Handscent for my texting with the pop-up to come over the lockscreen. I could hardly read any of the message when the screen would go out.
Here's what I found to get it to timeout for the amount you specify, touch the screen anywhere after it comes on. Then it will time out to the two minutes I have it set for, if not off goes the screen.
At least it's been working that way for me since running BACKside back in January.
