benslgdroid
rockstar
They have made no progress at all in months on the Netflix app
Could some of you please check what it says in this file:
/sys/devices/system/soc/soc0/build_id
I have flashed LeslieAnn's radio zip file three times today, and it still says VM670ZV4
(I know, I'm late to the party, I like to make an appearance)![]()
If this turns out to be a reliable place to get the baseband info from, I can change the code in IHO based ROMs to show the baseband version under Settings>>About phone. It currently is setup to check for gsm basebands, since cdma isn't officially supported. I'm just not sure if that file is written by the ROM, or it's value is grabbed from the modem. Only those that can double check with gpst will know for sure.![]()
Note- the file exists on the stock donor phone, and it shows ZV9, so I'm hopeful this could work!
VM670ZV4 on my phone.Could some of you please check what it says in this file:
Not sure why I can't flash 04-01 properly. Perhaps I need gapps? Might have flashed the wrong ones. I had backed up all of my apps and when I rebooted, it wanted my Google info, fine. When I tried to restore my apps, I got a message about not having the space to do it. I was really digging the new Quicksilver theme, so I'm a bit sad. So gapps or what, guys?
If your coming from such an early build there was recently changes. A little back there is a few long discussions on the topic.
I'm beginning to think those who have issues with GPS may have a hardware issue. Definitely not certain about it yet, but I have never had an issue with GPS, and only a handful of users have ever complained about it. One of the IHO devs, mrg666 has two OVs, and one gives him GPS trouble, so I'm leaning towards hardware on this one.Google nav still not working keeps saying searching for satellites or signal lost. Copilot worked for the most part. On a side note I have an external TomTom Bluetooth GPS receiver I used with my Centro and finally got it to pair and work with maps and nav right away but I didn't drive anywhere but the location was spot on. I do understand in general it is a better receiver.
Let me tell you when your use to driving in an ordered streets setup L.A. streets suck.
Could you be a bit more specific, what freezes, what do you do before it freezes, what do you do to unfreeze it, etc. And of course, be sure you haveStill freezing on the 4-01 build.... this is dreadful..... =[
I believe I had that unchecked, if you're talking about the fade in thing from each app. I remember reading about that problem and doing the suggestion and it froze.=/ It usually freezes on instant messaging, or sometimes it will freeze on the lock screen. Sometimes HALF the screen will freeze and I can see just half a screen. I can be doing anything and it will freeze on it, and I take out the battery to unfreeze it.Could you be a bit more specific, what freezes, what do you do before it freezes, what do you do to unfreeze it, etc. And of course, be sure you have
Settings>>Display settings>>Rotation animations (unchecked).
Over 1200 downloads, and so far, your's is the only report of freezing.
