mishmosh2000
Member
Could some of you please check what it says in this file:
/sys/devices/system/soc/soc0/build_id
I had flashed the radio too and it says:
VM670ZV5
I'm beginning to think those who have issues with GPS may have a hardware issue. Definitely not certain about it yet, but I have never had an issue with GPS, and only a handful of users have ever complained about it. One of the IHO devs, mrg666 has two OVs, and one gives him GPS trouble, so I'm leaning towards hardware on this one.
In QPST open EFS Explorer, in "err" folder there is some modem crash log files in which you can see the radio version and it's the old one. If your modem didn't crash after radio update you can't be sure what the radio version is currently on phone. That is the only place I could find radio version in QPST.
But CDMA Workshop shows radio version read from phone with build date and everything and it is the old one so I think Jerry is right. The radio update is not flashed.
I'm wondering if flashing radio.img in bootloader with fastboot would work!?
kwknott, can you check your radio version with CDMA Workshop?
Thanks for all the feedback on the radio. I'm investigating various methods to get the radio to flash properly. I just wish people had been patient in the beginning when I asked them to be. Now I have to dig through each persons flashing history to determine what worked and what didn't.![]()
kwknott, what
shows now?
Noooo.I'm leaning so far towards the stock recovery having something extra to write the radio, I'm about to fall over.![]()
I know what you mean, it's been so strange working with the donor phone, I hadn't seen stock in over a year before I received it.Noooo.
I do not think I can take BACKside off the phone and make it stock to flash it!![]()
IMHO, it's simpler (and safer) to do a nandroid, then flash the security update twice, then use Gordita Root, then restore nandroid.
Since we don't know exactly how the radio is flashed, and why it takes a second boot, I prefer this method.
Note- I assume the install-recovery.sh file is adding the what's needed during the first boot after flashing the update.zip, since it applies a patch. Once this patch is applied, then the radio seems to flash fine.
