JerryScript
Android Expert
No problem at all, you can use TB to uninstall the Gallery3d. But of course, you'll have to do it each time you install an update to your ROM.
I don't want to flood this Backside ROM thread...maybe Brotherswing will make a new thread tomorrow with a how2. But from what I gather, most are using their 3rd party recovery to flash the VM update.zip. Not sure why, but you need to flash the update again through the stock recovery (or settings/about.phone/sw.update once rebooted). The first time, I couldn't boot to stock so I went to stock recovery (home.button+down.volume+ power.on) to do a factory reset.
Have you tried a clean install instead of an upgrade? I don't use ADW either, and I never have issues.
+1 QuickPic, I wish it was open source, it would be in BACKside!![]()
The only reason I keep the default Gallery is that it links to my Picasa Album. Can QuickPic do that too??
Read back around April 1
You need to delete the April Fools zip in /system/media. That's the only way to get rid of it.
Hey guys, flashed the newest version of BACKside today and I'm experiencing several problems. First off, I'm getting a notification that my storage space is very low. After checking, it seems I have lost a lot of internal storage with the latest build. A lot of my apps are also not appearing in drawer and I cannot access them.
I'm not sure the exact version I had on my phone before, but I think it was a build from sometime in January. I checked the first post of this thread for any further instructions with the latest build and I can't see where I did anything wrong.
Any advice?
Try using E.S. file explorer. It has the ability to change your system from r/o to r/w and back to r/o. It can be a little hard to navigate some times. I go into the settings and change the home directory from /sdcard to /. This makes it easier to navigate.Yeah, I found the file using Astro. I try to delete it and it says error deleting files![]()
