JerryScript
Android Expert
Actually, the dalvik cache is in it's normal place now, what I did was stop it from being moved to the same partition downloads go to before being installed. That was preventing us from being able to use a lot of space, even though it showed as available. Now you see less space, but what you see is actually usable.
Check out the work being done on magpie. It requires an ext partition on your sdcard, but you will be able to move all app files to sd, and not worry about re-linking them after a ROM install. I'm watching it, and considering adding it to BACKside soon.
