Junkyarddog269
Member
I didn't have any trouble myself
CWM-Green is not V3.3, the BacksideUpdater is V3.3Is anyone else having troubles getting the new Green recovery to install? I see it installing through the backside updater on my phone, but then even if I reboot the phone and go back in there it still says version 3.2. I even tried to flash it via recovery but I cannot see the img file in the Downloads directory.
I even made sure that I wasn't trying to install the previous version.. I deleted it off my SD card. Any ideas?
If you open the BacksideUpdater, then select Show All Versions, the latest version of CWM-Green is always at the bottom of the list.Thank you Jerry! I think I'm more excited about the update to your recovery than the ROM itself! One suggestion though, it would be nice if the updater could check for updates for your recovery as well. I have no idea what it would take to code that, or even if it's possible, but I think that would give your work a more integrated, polished feel.
There is the tvall kernel in the ATR Guide sticky you can flash to tied you over untill the next update. Just flash it. No wipe. Should see a little zippier response.
Not sure if it's supposed to work correctly yet, but just thought I'd mention it.
Seems like my auto-install function doesn't work. The phone boots into recovery, wipes cache, doesn't wipe dalvik, then the phone reboots without installing anything. Using 5-2 CWM green recovery and updating from 4-17 to 5-2 ROM.
I experienced the same thing. As far as the md5 goes, mine was okay but the download straight up failed five times. I was getting abysmal transfer speeds, then it would hang around forty megs. About an hour later it downloaded without a problem, like it always does. Whatever was going on isn't Jerry's fault. I'm a little bummed the new auto update misfired, I know it was working before...maybe it works with the previous version? I've had probably a dozen different recoveries on my phone over the past year or so, now I can't remember which did what!Not sure if it's supposed to work correctly yet, but just thought I'd mention it.
I tried it with Link2SD and it didn't play well at all.
