JerryScript
Android Expert
Looks like mrg666 removed them, I'll see about getting them back up.
I'm fairly sure thats not the problem, I've set the CPU to stock as well as underclocking it, and the issue still remains. Would anyone recommend a completely fresh install, or is there some way of troubleshooting?
Fantastic ROM! I'm loving it. The battery drains a bit quickly. That is the only thing I found wrong with it. But other than that it's terrific.
A couple questions...
1) Any way I could get rid of the IHO boot image?
2) Any chance on making the Green Machine theme in other colors, like pink or blue?
Thanks a lot for making such a great ROM!
Should work fine, mmarz's work is amazing!forums.androidcentral.com/optimus-v-rooting-roms-hacks/84862-mod-script-toggle-keylights-part-ii.html#post908993
is this mod possable with the back side rom
1) The IHO boot image replaces the red LGE boot image. I can remove them all together, but that leaves a blank screen that makes you wonder if the phone is booting or not, IMO you need something there.
Okay well how would I go about using my own splash screen?
Build #08202011 seems a little unstable. I set the CPU speed down to 600MHz and it's still occasionally reboots,and sometimes gets stuck in the boot animation. Was in the middle of a Bluetooth call and Bluetooth quit. Had to finish the call with phone stuck to face while driving ,after I dug it out of my pocket. The gallery is worse than ever before,even at 600Hz with reboot and using the media scanner in Dev Tools. OK now It's frezzing then rebooting at 600MHz. I'm going to try something. I'm going to Reinstall CWM 3.2.0.1 and reinstall ROM and see if that doesn't cure the problems. Or maybe I should flash everything including a new set of Gapps.
Other than that, everything else seems to work fine.
I installed build #08202011 over build #08172011(wiped cache partition and dalvik cache only) which is why if every body else was having problems with it I decided a fresh install might be necessary. I was already starting the process before I read you thread. Just waiting on Titanium to finish with the batch install of apps.Sounds like you need to do a fresh install, I would try wiping cache/dalvik and reflashing, then testing to see if it works before going through a complete format. If it still gives you troubles, you will need to do a complete format, but you are the first I've heard with these issues, so hopefully a re-flash will suffice.![]()
Whenever I record video I get a good picture but no sound. Anyone else having that issue?
To change the colors of the green machine theme, you would need to know all the settings I used, missing even one would look strange. Best bet is to create your own at UOT Kitchen.lets say i wanted to edit the green machine like as in change the color .. what program would i use .. would i do it here UOT Kitchen ... or is there some where else
Give it a reboot or two. Sometimes after installing, as the cache is being rebuilt some things get into a race situation, which can cause FCs. If it persists after a few reboots, you may need to redownload and reflash.I'm noticing alot of force closes on 8202011. I formatted the cache and delvik cache and also did boot, system, data, etc. (3x each cuz I'm using xiona lol) but yeah, I erased everything and started fresh and I'm having FC issues.
Perhaps try uninstalling and reinstalling the game.has anyone tried the game Inotia3 on this rom? I tried it and it shows loading but then becomes a black screen. It worked on stock.. Any ideas?
