exProphecy
those are only the live wallpapers. The default ones aren't there...
Yes this is also still a problem for me xD I wanted the default Cyanogenmod wallpapers =[
Those are cool and everything... but where did the "stock" wallpapers go? Every Optimus V comes pre-installed with both regular and live wallpapers. They are there when you get the phone and don't flash a rom on there.Wallpapers are attached to this post![]()
I have another question: you know when you first flash the ROM onto the phone and in the setup process, it asks you if you'd like to install some apps (Gmail, Google Voice, Google Goggles, Facebook, etc)? If I click cancel and choose to install it later, how do I go about doing that? I clicked cancel but how do I use that again to install those apps?
EDIT: NEVERMIND. Apparently, it only appears once. Your chance is lost if you choose cancel. No biggie since you can download it yourself manually if you really want it.
I still can't find a way to get to the live wallpapers. It's set to the default Nexus live wallpaper. But the live wallpaper option is missing from the wallpaper menu. In the menu there is: "Configure...", "Gallery", "QuickPic Wallpaper", and "Wallpaper gallery". If I change the wallpaper, I have no way of getting back to the Nexus wallpaper.
I had a problem with 3g not working. I fixed it by restoring to my stock backup and enabling 3g, and then flashing to BACKside again. I thought, maybe having a live wallpaper enabled when I flashed to BACKside was the reason I didn't have live wallpaper, so I flashed back to stock, reset to factory defaults, and flashed to BACKside again. No luck.
The application Android Live Wallpapers (process com.android.wallpaper) has stopped unexpectedly. Please try again.
If you go back to the first page,first post, you will see the change log(those things that got changed in a particular build) for your build #can someone please tell me how the current build is different from the 0810 build?
Try this :I installed a live wallpaper from the market and found a way to run it, but it didn't actually start. It immediately gave me an error.
When I try to change the config of the default Nexus wallpaper, I can change the background and stuff, but if I keep messing with it, it gives me the same error.
Tried it. Didn't work. =[. These lines are very deliberate, I've seen them in google goggles before...Try turning down your cpu overclock speed, the camera app is almost always affected by too high of an overclock.
Whats the average battery life of someone with 3g on? i lose like 15% an hour with 3g on and i hate it, although it could also be that i have yahoo and facebook connected as well as auto sync set to on. and also battery defender and all those things only make my battery go down faster.
I'm currently using aosp, and I pretty consistently use about 5% per hour with very light use and a very weak signal. Don't know if that helps you.anybody?
anybody?
anybody?
mms works fine without 3G. You just won't get your picture mms until you turn 3G back on.If I turn off my 3g will I still receive a notification that I have a mms and be able to turn my 3g on to download it?
