benslgdroid
rockstar
It was in the settings and let me select it but nothing could access it.
Hey JerryScript, Installed Build #08172011 and my GPS works super. Is the problem with GPS isolated to those that flash the theme with the ROM,or is it happening to those coming from another ROM. I also didn't flash the Gapps. I flashed the ROM, rebooted twice, then flashed the theme. Every thing is working fine for me. I also make sure that before flashing anything on a new build my CPU speed is set to 600MHz-245MHz. When everything looks good I move up to 768-480. I'm getting great battery off charge time and battery temp is low.I've removed the link on the OP and the wiki to the 0817 build due to gps issues. Will post a new build soon, till then use the 0810 or one of the other IHO builds if you need GPS and already flashed the 0817 build. Sorry for the inconvenience.
EDIT: The headset jack plays music fine,but can not transmit my voice during calls. I Can here person on other end just fine,but they can't here me. Again, sorry!
It's a little slow to go to green from off or screen off(5-6 sec.),but works just fine. I've had it turned off and on maybe 2 dozen times.Try turning GPS off then back on, and let me know if it still works. Thanks!
Works fine for me. ? what was your stock OS did you have 2.2.1 or 2.2.2Jerry, as much as I want to contribute to this project, I'm an idiot when it comes to programming. So I hate to ask such an ignorant question but here goes : at one point USB mass storage worked. I think back on the 7-21 build. What caused it to stop working and does Blarfie have an ETA or favorable news about it? This latest build is a good example of a randomly lost feature. It kind of made me think about the number one feature I've been missing from the stock rom: Mass Storage.
Edit: a better question is does blarfie have a blog or anything about his work? The iho page didn't seem to have the info I was hunting.
What OS do you have? 2.2.1,or 2.2.2I updated from the 8/10 ROM to the 8/17 rom. The GPS section in the settings menu disappeared, and the GPS toggle button on the notification window stopped working. I cleared the cache and the dalvik cache before updating.
I'm not sure about Groove IP, but when using wifi and the built-in VoiP using my sipgate account with google voice, it's very clear. I would say try to get it to work on wifi first to isolate the problem. VM's 3G data isn't as stable for VoiP calls right now.
Maybe you could start a thread and explain what you have found that works with the 10.1 flash player and your progress on the 10.2.i believe jerry mistakenly left them off that build. there is a separate zip file to flash that includes the live wallpapers. i just flashed it over my existing build.
does anybody know if adobe flash 10.2 works with our phone? i have flash 10.1 working, but no luck yet with 10.2.
I only ask because I myself have not been able to get anything to work using the 10.1,but would like to be able to get away from having to use the skyfire browser all the time and just use a browser of my choice.
The question was sort of a trouble shooting type of question(although a bit out there). I was Froyo 2.2.1 and have never had a major problem with USB mass storage on any of the BACKside builds. Plus my WiFi works fine on build #08172011. Was just doing a little fishing for JerryScript.I don't really remember what my stock rom was. I'm guessing 2.2.2 but I have no clue. I got it from BestBuy and my first alteration was to take it from the stock rom to Jerry's rom. I have loved it but I use USB mass storage at least once a day every day and now I don't have it.
It worked on the stock rom if that's what you're asking.
I was just curious why all the builds prior to 7/21 didn't mention anything about mass storage drivers not working, then all the sudden they drop out. It's strange how when changing various parts of the build, something can just drop out for seemingly no reason. I really wanna learn how to do this stuff. It is so intriguing to me!!!!
Still Looking for these answers but I have a different question if someone can humor me! ;p1. Where is the built in VoiP?
2. Are these free phone calls?
Thanks!
