This rom is great! Feels faster than aospcmod. However, I had mms working there, but when I switched to backside whenever I send an mms it remains forever stuck at "Sending.."
Sorry JerryScript, looks like you got it under controloops again! i found theme chooser. i was looking in the wrong place. its been a long night. i also came across an old post on this thread where somebody else brought up the text to speech question. i checked the market but am not seeing a google option. i do have google voice. is there something else i should be looking for?
also, has anyone else noticed that wallpaper from the market appears to be zoomed in when you apply it? i have the market download antique cm walls and all appear to be zoomed in too much after i apply it.
Look in your app drawer for Voice Search. That is the app that needs to be installed. If it isn't, download it from the market, be sure it's Google Voice Search.
https://market.android.com/details?id=com.google.android.voicesearch&feature=search_result
@benslgdroid: That options should be there. Try reflashing the ROM and gapps, just wipe cache and dalvik, don't format anything or reset to defaults. When you setup google, be sure to select to install anything that says voice on it.
MMS works fine. If it isn't working for you, first be sure you have 3g working (try sending a SMS to test). If 3g is fine, then you most likely restored a system app and/or it's data. To get MMS working again, first backup your apps with TitaniumBackup or MyBackup, but DO NOT BACKUP SYSTEM APPS OR DATA! Then go into recovery and wipe cache/dalvik, then under mounts format boot, data, system, and cache. Then reflash the ROM and gapps. Reboot, be sure 3g is enabled, and test MMS. If it all works, then restore your apps, but DO NOT RESTORE ANY SYSTEM APPS OR DATA!!!
I just tested MMS, and it worked fine.![]()
Do we need to format?
the gps doesn't turn on for me in this new version
Don't need to tell me twice, I'm all over it!New BACKside-IHO build is up 08172011
Changes to GPS to hopefully help battery life, second sdcard partition should be recognized, changed the second boot logo, and a bunch of minor behind the scenes tweaks
See the wiki for download links and md5sum.![]()
Me, either. I guess I'll try the jyklly version.the gps doesn't turn on for me in this new version
No gps
Well, that fixed GPS, but Netflix no longer works.Me, either. I guess I'll try the jyklly version.
Hey! Those fish are looking a little better than the last poor little thang. Can't wait till you catch an 8-10lb fish.Just updated to the 8/17 ROM. GPS is missing in the settings screen. I tried turning it on with the shortcut icon in the notification window, but that didn't work.
