okay so i did all the steps and then my phone booted fine and i had 2.3.5 installed on my optimus v but now i dont have my coontacts and texts how to get them back??
Were you coming from the stock ROM? If so you must do all these things:flashing stock everything because no one will help a crying boy
1.wipe cache partition.
2.wipe dalvik cache(advanced section)
3.wipe data/factory reset.Now that your rooted YOU MUST NEVER USE THE FACTORY RESET IN THE PRIVACY MENU ON THE PHONE
4.format boot,system,data,and cache
5.go to install zip from sd card
6.go to select zip from sd card,chose the ROM zip first. It will go thru the install procedure. When done go back to step 6. and select the gapps zip.
When all this is done select reboot system now.
It will take 5-10min. for the initial reboot. You will be asked to sign in,skip this. Then go to your Market app and sing in from there.
I can no longer shut off my phone while plugged in. Selecting power off just reboots it.
ive got a quick question, concerning titanium backup (free)
when you create a "update.zip" does that work more or less like installing gapps.zip.
like is creating a "update.zip" file via titanium backup basically packing all of your apps into a .zip file, and then you can install from sd(or apply update.zip from sd), and it will unpack it and batch install all your apps?
im just wondering, cause if so, then wouldnt this be faster to do instead of backing up, and restoring all your apps everytime you flash a rom.
I followed the directions EXACTILLY that were posted and it's bricked it wont take any other tons now... I'm going to take it to best buy seeing it's less then 30 days before purchase and get it replaced
Sorry for my actions last night
