mkbkr1
Hi all,
I actually have BobZHome's build, but I imagine the problems might be the same. I'm trying to port my old sprint number to my new VM plan, and I'm now at the part where I have to enter ##VIRGIN# to program the phone with the new MDN and MSID. The problem is nothing happens when I enter that key combo. It just stays there and doesn't enter the Service Program menu that it's supposed to. Is there an alternate way to get to this menu or is my only to choice to flash back to stock android?
Thanks.
You either have to reload your stock backup (you do have one, don't you), or flash one of the froyo based roms. The activation app and programming menu will not work on gingerbread roms. Once your done, you can restore your current rom.
