MacFett
Android Expert
Yes, the correct file is BACKside-IHO-VM670-10042011.zipI noticed that the file was named: BACKside-IHO-VM670-09282011.zip, but the update came out on 10/4. Is it the wrong file?
Flashed, first impression... Don't like the new unlock. I haven't had time to really run it and see anything else, so this is purely an visual thing. Also did you nix the self destruct start up sound?
I haven't had time to get it but there is an app called widget locker you can design your own lock screen.
Yeah I played with it too a while ago. Wasn't very intuitive... at all. I've seen some locks that other people created but for some reason I couldn't get it to work right. I like the new unlocker that BobZhome has. I don't know if it's in BackSide or not.I've messed wit WL before and it seemed to mess stuff up unless you got the paid app.
I had went to the 1st post and downloaded the ROM described as the 10042011.zip and wasn't paying attention to the actual description in the download box I clicked on,and got the 09282011 build instead. Still didn't notice on my PC,just clicked on the BACKside ROM with the correct download date(I was half asleep at this time,but couldn't wait to flash it).Yes, the correct file is BACKside-IHO-VM670-10042011.zip
It's based on the 09282011 BACKSide build with the BobZhome v2 kernel. I'm sure once they figure out that there is a new BACKside with the v3.1 kernel they will be updating.Yeah I played with it too a while ago. Wasn't very intuitive... at all. I've seen some locks that other people created but for some reason I couldn't get it to work right. I like the new unlocker that BobZhome has. I don't know if it's in BackSide or not.
Right now I'm testing a new IHO ROM Sonygenmod found here. AndyOpie mentioned it earlier. Not too bad and I like the interface. Still in alpha, I'm getting alot of FC's but very very interesting!!
Sorry,It's in obijohn's Bumblebee ROM site http://forums.androidcentral.com/op...-memory-kernel-bumblebee-2-4-6-25-2011-a.htmlDo you have a link to the wiper.zip??
Is there a way to get more than one custom application for the ring lockscreen style?
That would be a lot more useful. The Optimus V has a smaller screen, but it looks like you could fit at least 2 or 3 custom applications on the screen.
This version has 4 custom applications: http://www.youtube.com/watch?v=E7etPPvbl4Q
Yeah, Daxelectro mentioned that an update for us is coming on the 8th. This is the fun part of all of this... you flash JerryScript, Bobz and anything that you might be interested in and try them out. You get a new phone everytime you do!!It's based on the 09282011 BACKSide build with the BobZhome v2 kernel. I'm sure once they figure out that there is a new BACKside with the v3.1 kernel they will be updating.
I don't know what app it was then. It looked like widget launcher. It was free and had some free locks, but most of the stuff you had to pay and if you applied something free it only half way worked and after you unlocked with it you'd see the regular lock controls for a sec.WL doesn't have a free version. It's a kickass app though. Was the first app I ever bought.
After using the new style for the afternoon, I'm not hating the lock screen. It was just the initial unwanted change. I am okay now though.The lockscreen style is an option, the others are all still there under
settings>>CyanogenMod settings>>Lockscreen>>Style options>>Lockscreen style
There is a new setting that may help/hurt, I don't use either of those apps, so I would appreciate if you could try them and see if they make any difference.This is weird. The 10/4 update fixed the transparency glitch in the Facebook app, but didn't fix it in the Pulse News app.
It's better than the last build, but still not perfect yet. Keep up the good work.
This ROM doesn't appear to have CIFS support. Would it be possible to add it? It would be great to use CIFSmanager and similar apps.
Oh my gosh you guys, me the one who needed extreme hand-holding to flash Harmonia a few months back, just flashed BACKside all by herself..and it worked! and it.is.beautiful! Mind=blownI feel like a kid in candy store...its gonna take me a few days to discover everything I can do with this
Thanks JerryScripts and everyone else who made this possible
Edit: I didn't change my recovery from xionia to clockworkmod or anything...is that ok? I tried, but it didn't know out so good...
Well hello stranger!
Glad to see you got the nerve up to move on up to CM7. You should be fine with xionia, though some people say they have issues with it, I have not. I've used every recovery available at one time or another, and haven't had any issues (except the thunderc recovery, it's way too old for me to even try)
