I just want to hug everyone involved in making my phone so spiffy...esp since i just discovered what theme chooser is for, and all the free cm7 themes in the market...eeee!! My phone is getting an awesome new Halloween themed makeover
I love how simple everything has been...reading about the other cm7 roms back before I took the plunge and flashed anything, they sounded so complicated and difficult to deal with, and this is just...easy and nice. One question tho- is it safe to use root toolz to change the system font? will that conflict with anything? Thank you thank you again
There's also allot of themes online made by individuals.
Make sure you have a 3g connection.
I'm still having problems with MMS. Can't send or download. Sending it shows a "sending..." that never goes away. Anyone else have this issue? Also does anyone know how to map the voice search button?
Would be nice if someone could post instructions on how to map the button manually, if possible, so we don't have to buy the app just for one button. Maybe it's as simple as editing a config file somewhere?Voice Dialer button is not mapped, use Button Remapper from the market and set it as you like.
From the first post, under known bugs:
JerryScript, is it your personal preference to not have the button mapped?
i know, i've got that xda thread bookmarked. im starting slow, checking out what i can do with the market ones, then i'll branch out to the others.
are the themes that are put in the market not made by individuals?
I just think of market items as commercial. Not really sure why I said it that way lol.
Sorry, I'm working on the problem right now.
Ran the code and it booted into the recovery I had chosen just fine.
Hey, how come we get all the goofy problems with are phones.
Will still be working on it.
When you wake up try using the old sd card with all the stuff it had on it before and try using Titianium Backup, then let me know what you get. It could be your new uSD card/Link2SD endeavor didn't quite turn out the way you had expected.
I had a bad download (even tho i downloaded it with the computer, which is why i didnt think to check that right away) and links2sd seems to be working well too. Im a happy camper
Any differences I should be aware of between CWM and xionia, besides using the camera button to select options?I'm still having problems with MMS. Can't send or download. Sending it shows a "sending..." that never goes away. Anyone else have this issue? Also does anyone know how to map the voice search button?
I'm know you don't want to hear this, but assuming your 3g service is up, the only solution is to do a full wipe/format and then redownload and reflash the ROM and gapps.
haha. I'll have to think about this.Are you using the newest gapps? Because when I was,I was having the same issue. I flashed back to the 6-something-2011 build and it fixed the problem for me
Would you happen to have that old gapps file handy, and if so... would you, could you, if you please, share?
Do I just reflash the gapps file you give me, or are there other steps (besides backup in recovery) that I need to follow before/after flashing this?
It should be on the OP on the first page of this thread towards the bottom. Click on "download latest version of gapps here" and when it takes you to the next page, check the date on the cm7 version. If it's dated for June 2011, it's the one i'm using. Sorry idk how to share links on mobile.
And I'd double check on this, but I think all you have to do is "wipe cache" and under advanced "wipe dalvik cache"
Edit: then you need to flash gapps. (lol)
Like I said, make sure that's right first, i'm just going off the top of my head. Sorry if i'm not much help right now, i'm at work
