benslgdroid
rockstar
people pc is likely not windows 7
No, but the company that branded her computer (People PC) likely put their own email program on there or branded another email client. /shrug
There is no more boot sound.. that's your answer lol, however, if you would like a boot sound, search boot animation changer lite (BAC lite for short) in the market, and install. Open it, allow superuser permissions, go to tools, remove mp3, un-install sound binary, install sound binary, import mp3. The mp3 can actually be any length, but its just safe to cut it down to 30 seconds or less.
As for the status bar, it fixes after you reboot your phone. If you change the theme, simply reboot your phone. I too experienced these issues on this build, and the previous build. Rebooting helped me.
With all the help given Sadie I was able to get up the nerve to make my own theme. Thank you.
Its a mix between green machine and rover
any chance of you sharing your theme? it looks nice, best of both worlds.
not possible we dont have the antenna for it.this mite be a noob question but i was wondering if there was a way to get 4g on the obtimus v ..
Well it looks really cool, I like the way you used certain elements of both themes. I'll be looking forward to useing it.
The one thing that makes the Rover theme unusable for me is that the status icons are too small to read on the Optimus. Makes the battery % pointless, IMO.
Another question, I'm having trouble checking checkboxes in browsers. Anyone else have this problem or have a solution on how to fix that? >_<
Cm7 just released what there calling a stable mod will that effect us
