@sadielynn: CW should be very similar to xionia, you've noticed the button changes, that's about it on the surface.
For a transparent status bar, look into UOT Kitchen while you're still around your mom's computer. You can create just a transparent status bar, or an entire theme, just by clicking on what you want. It's an amazing resource for customizing your phone! It's what I use to build my GreenMachine Theme each new build.![]()
anyone having any problems with phone calls being hung up on? my phone worked fantastically until today. all of a sudden (with good service mind you) the call just hangs up. it didnt give me the "call was dropped" logo and im not pressing end call by accident. when i receive a call and answer it, it hangs up almost immediately. when i place a call i get about 10 seconds and then it hangs up. this is extraordinarily aggravating. any suggestions?
VM is having an issue, check the thread here: http://androidforums.com/lg-optimus-v/425696-help-calls-ending-before-they-begin.html
ROFL!!!!!!!!
I searched for gapps earlier and I saw that link. I didn't open it because I thought it was a porn site hahaha.![]()
Seriously, was "goo inside me gapps" done on purpose?
Umm, yeah, I'll look again when I get home from work, but I looked at the kitchen the other day, and couldn't make heads or tails of it. I'm pretty sure it's wants you to know what files change the thing your trying to mod, and pull the files out of the rom and alot of other scary things. If it was a simple 'I want this, so I click it and then pick changes to make, then click done and download' id be OK, but it looked terribly complex to me
EDIT: ok, I'm an idiot, its not that hard. That being said, I made a zip to allow for status bar transparency, but it didn't work. got the status (0) error or whatever. Followed the directions on the kitchen page to fix it, still doesn't work. just says installation aborted. I had no idea what to do on the summary page, so I just sort of winged it-im guessing i didnt do it right. Or i did something wrong when i replaced the file in the zip to correct the error. Winzip came up with a whole page of options to set when adding the file, and again, had no idea what to choose, so winged it. blah.
The issue is probably with using WinZip, quite possibly the worst archive software ever made. Try using 7zip, and when you make any changes, be sure it is set to "store". That should fix your status (0) issue.![]()
I don't know what could be causing your status bar issues. Are you sure you don't have it set to be hidden in the settings menus?
ok, I downloaded 7zip too, so ill try that. ThanksBTW, if all i did in UOT kitchen was select status bar, then "allow transparent status bar" and nothing else, that will just allow themes to make it transparent, not automatically make it transparent all the time, right?
i dont have an email account set up on this computer, so i can't email it to myself.
On your computer if you go to Google and click on the Gmail link up top, it should ask you for your Gmail login and pass.. this is the same login and pass that you use for Gmail on your phone.![]()
To extract/replace files with 7-zip, right click on the file, and under 7-zip select open archive. Drag the files you want out of it onto another folder or your desktop, you want the /system/app/SystemUI.apk and /system/frameworks/frameworks-res.apk. Upload those to UOT Kitchen and create your theme. Download the UOT Kitchen theme, put it on your sdcard, reboot into recovery, under the install section try toggling signature verification, then flash the UOT theme.
I don't recommend making a theme chooser theme, it doesn't include all the changes you get from a flashable zip package.
yeah, i got that, it just won't default to my gmail when wants to email the zip, it just brings up the peoplepc email program that came with the computer.
