Prometheus_
Member
+1 Here, LP is an amazing app!As for the rest of the screen I use launcher pro
You two should collaborate, lol. Do you use Metamorph to help you edit your themes? I'm interested in building my own now.
I use uot kitchen at the moment but do plan on looking into something I can use to create my own icons and also edit system icons the way in which rover did theres. I just don't have alot of time to dedicate with taking care of my kids.
its ok, take your time, your two themes are great (Grover being my favorite!)
and on a side note, I recently noticed that the IHO roms(mirage, backside, and bobzhomes roms) are now available through Rom Manager. although it may not update as soon as a new build is released, but it sure was an exciting site to behold!![]()
Um, the ROM developer is supposed to submit the ROM to ROM Manager, and I never did, so eye this with suspicion!
Neither have IUm, the ROM developer is supposed to submit the ROM to ROM Manager, and I never did, so eye this with suspicion!
Anyone have problems with Navigation? I used it yesterday and it was very slow when I tried changing options. After I had it set up, at one point during the trip it completely locked up. Luckily I was watching the distance info and noticed it wasn't changing.
Also, I'd like to renew my request for CIFS. Any chance it could be enabled in the next build?
I doubt it's ROM related, more likely Links2SD related.
Did you have the skin's files stored on the phone's internal memory, or moved to the sdcard's ext partition via Links2SD?
Try clearing your Market's data and cache.i apparently cannot download from the market. i can go to it and search and select apps, but the download just hangs. i have tried on wifi and on 3g. am i missing something? thanks again
CIFS is enabled in the most recent two BACKside builds, and I believe in the most recent builds by BobZhome and mrg666.![]()
sorry if i missed any responses about this, but i dont have a working bluetooth situation here. i have flashed the 1017 build, and everything seems to be fine except the bluetooth. it doesnt see any devices. i have more than one bluetooth set. am i just slow to recognize the solution or is this inherent in the build? Thanks fellas.
I just paired my bluetooth 3.0 mini keyboard with no issues. Haven't tried a headset, but at least I do know BT will pair.![]()
About how much does a Bluetooth keyboard cost? And do you know if a Bluetooth mouse works with our phone?
