I take it that the new build is good and no problems to report? I'm waiting a little bit for now on before I jump into a build that has problems.
Jerry,
First, thank you again for all of the work that you put into each build.
Second, I'm still running into the dalvik cache problem with this build. It again hits a certain point and then says there is no memory, either for reinstalling apps or downloading from the Market.
I have hit no problems with it. Seems to be running very smooth for me.
Have you tried a fresh install instead of just flashing over your previous build?
Dumb question...
What is the easiest way to do a rom update if you're using link2sd? I just tried to update by clearing the cache and dalvik cache, and all of my apps were missing after it booted into backside rom. I opened link2sd, and it wanted to do a "quick reboot" to fix the 2nd partition, but it just got stuck in the boot animation.
Do I have to do a clean install for every update if I'm using link2sd?
Yes, in fact I've done four fresh installs: the first time updating the ROM, then to see if it was a bad install, then to see if I had neglected to move the apps, and the last time to move the dalvik cache file to the SD. I did fresh installs from the beginning because I had a few crashes and resets with the last ROM and wanted a fresh install, just to make sure everything was cleaned out. During the first installs I would eventually hit the "limit." Only by moving the dalvik cache to the SD was I able to again install all apps and use the market. It's been that way over the last few builds.
So you cleared data, cache, dalvik cache, then formatted boot, system, data, cache, sd-ext, and then flashed? (I usually go into mounts and storage just to make sure everything is wiped clean)
Yep...I've been installing and re-installing since 7:00 am this morning.
That is very strange. Now are you using app2sd or anything like that and if so are you trying to set that up before you run into the issue?
I've tried using APP2SD and moving the programs as they installed, but that didn't stop the problem. During one of the the most recent installations, I tried used Titanium Pro to move the apps to the SD and still the only thing that worked was moving the cache file itself. Once I do that, I can install anything and everything. I'd say that it started happening with one of the first October builds. (I'm not sure specifically, but I posted in the forum when it first happened, so I could go back and check.)
I did see that post and if that fix worked before I would do it again. I don't know to much about app2sd since I don't use it myself. I go with data2ext to clear up my system memory and to have a GB of space for apps. Here's a good link with step by step instructions if anyone is interested. Just keep in mind its either app2sd or data2ext or link2sd. I don't believe you can use these at the same time.
Here's the link if anyone wanted to play with data2ext:
http://optimusv.wikispaces.com/Moving+data+directory+to+MicroSD+with+Data2ext
*Edit*
Oh and the reason I was asking if you were implementing app2sd was because I was seeing if maybe that could be the root of your issue.
Sure, I appreciate it! Perhaps I should try partitioning the SD card? Anyway, it would be interesting to know what changed in the most recent builds.
With link2sd you have to have a fresh install every time
Are you sure? There HAS to be a way to do a rom update with link2sd without having to do a fresh install. LAME. hahaha
Every time I flash a new ROM from scratch I end up getting a handful of SMS and MMS that were sent sometimes weeks prior. I am typically running the newest BACKside.
Most of the messages come from my wife who is also using an Optimus V running BACKside 1017, but also some from my sister who has Verizon.
Any ideas on how to get these messages except flashing again?
New ones I've never received.are they new messages that you never received, or are they duplicates?
