benslgdroid
rockstar
The restore worked great, phone is fine except the market won't load...........any ideas for that one? I just get force closes.
Install the new market [Download] Android Market 3.3.11 Update Brings New Welcomed Features
Hey Jerry, do themes need to be redone for this build, or will the ones made for the 11/2 build still work?
Every new build has to have a new theme built because of the files used from within the build
Gonna wait till I get back from vacation so I can flash Jerry's new build (I think I'm two builds behind now), and try to install the new Market. Should be back in Chicago on Sunday at the latest.
Sigh Jerry, no Music 4.0.1 again?![]()
BTW, an update on my phone. I reverted back to an earlier version of my theme, and my phone was dead so i guess it shut off and back on lol. So far so good, my battery is working once more. Idk what that hiccup was but I didn't like it haha XD
^ is there an an app or are you just talking about the mobile site. I find the mobile site a bit hard to maneuver through on the phone so I prefer using it on the computer.
Check it outIt should be there, I did remember to add it this time, and it shows up on my phone.![]()
Anyone elses music player not update to Music 4.0.1?Well, this is odd. I can never text an e-mail, unless I enable VM's data mobile network which I really don't want to with the last build. I mean I can text e-mails, not send e-mail a person, just text just fine without doing that in VM's stock. Anywho, now the new build..I can't seem to do that as the previous build...is there a fix for this? Thanks!
Hmm I updated and I still have the regular music playerAnyone elses music player not update to Music 4.0.1?
Sorry, I'm completely new to using roms and I really love this one. I used to be able to send texts to people's emails, not using Virgin Mobile's preinstalled Gmail or Email apps, just fine when I just use the VM's stock rom, but when I use this one, it says "Sending...". It's like that for a while and only time my texts ever gets sent is when I connect to Virgin Mobile's mobile network. Again, I apologize if I'm not explaning this right.I'm sorry, I really don't understand what you are saying?![]()
The themes have to match the date of the rom you have. It replaces main files and if its not the right build it wont work.
The theme is installable like any other app through theme chooser. Its not like the other themes where it is flashed.
I just use the CM7 feature that allows dragging the notification bar to set brightness, top left corner is lowest, middle is 50%, right is 100%. It's quicker and more precise than toggling through the preset brightness settings.
(yes I used that too but the brightness still didn't stick; now it does though)^ is there an an app or are you just talking about the mobile site. I find the mobile site a bit hard to maneuver through on the phone so I prefer using it on the computer.
Does anyone else still have the old music player on 11092011 or is it just me?
