Ooh Noo, I'm breaking up.
Yours was the only report, so for the time being, I'm treating it as one of those things. If others report issues, I'll dig into it deeper.Darn it Jerry! You work too fast! Ever figure out why my one theme crashed the status bar, or was that isolated to my phone?
Yeah, I don't know why CM added those, I think they are ugly. However, I use my GreenMachineTheme with HDPI lockscreen icons, so it's not nearly as visually distracting.Flashed new rom. Lock screen buttons are still arrow-tastic.![]()
Ah, that makes sense. I don't use bootanimations bigger than 100 frames, and I never use a part1 folder, just the part0. That's why I didn't see a big difference.I'm thinking it will give some phones a bigger boost, and some bootanimations will offer greater boost when disabled. For phones, a larger screen means more calculations for each image displayed. For bootanimations, the more images used, the greater the performance boost when not being used. This should just apply to the amount of time it takes to initialize each frame of the animation, so for smaller bootanimations, the change will be negligible.![]()
Turn it down first, then you can turn it up.
