Hi all,
I just got the phone a few days ago and completed the steps outlined in the guide, everything seemed to go well, phone was rooted, roms were installed, phone was then rebooted, green theme looked great, but for some reason I seem to have lost root access as part of the process and no longer able to gingerbreak it again to get root. So the phone seems to be working fine, but I don't seem to have root anymore.
I tried to reinstall busybox but unable to install it. According to the superuser app it is granting super user status to apps that are requesting it, however they don't seem to be working e.g. astro when trying to install busybox.
The same is true when using a ConnectBot or any terminal emulator, I get the prompt just fine, "su" command seems to go through fine, but I get permission denied when I issue simple commands like "ls", "pwd" and "cd" work, but that's about it, anything more fancy like "grep" or "which" fails with "permission denied".
Interestingly I am not able to turn the device off any longer it simple reboots when I ask it to power off. Suspect this is related.
Not sure what the issue is, or if anyone else has had similar problems. Anyhow, here are the versions of the rooms I used.
- GingerBreak-v1.20.apk
- BACKside-IHO-VM670-12162011.zip
- gapps-gb-20110828-signed.zip
- GreenMachineTheme-12162011.zip
Android version after flashing roms according to my phone is now 2.3.7 (used to be 2.2.2)
Any assistance greatly appreciated.
