brotherswing
Android Expert
Does Skype use the in call volume, or the media stream?
Get a volume app that allows you to control the system volume.
A lot easier than digging into the settings all the time.
Then you should try Andy's advice and see what's in the market.
And this is just through your headset?
Just tried it and it doesn't help.. the volume barely changes.. This is exclusive to the dialer actually.. The volume in skype is really easy to hear.
This may be a stupid suggestion, but since it apply exclusively to the dialer, maybe try a third party dialer? I use ex dialer, for example.
When did this issue start? I mean, have you updated to the new rom yet?
I did some extensive googling before posting in the thread, so I already had tried the DSP manager advice, but it didn't work.Bala July 6, 2011
Hi ,
Your blog is very interesting and so good to read.
I have a small issues with CM7 custom ROM .
The IN-CALL volume through headphones is very low, However the music and all other sounds are perfect.
Do you have any idea abt this bug in CM?
Let me know if there is any particular fix for it. ?
Reply
Sanjeev July 6, 2011
You can try changing the DSP Manager settings. In DSP Manager select the headset setting and then Enable Equalizer.
You can use the preset as small speakers or configure a custom one.
For custom setting click on the graph and pull each point to maximum (10). This will increase the headphone volume. Select the level of volume according to your liking.
Hope this will resolve your issue.
There is a bug in the ROM, but he's already tried that trick. I'm starting to think it may be a bad flash, since it didn't start until he updated to 1221.
@Idun, did you check the md5 checksum? Your download might be a tad wonky.
Go back to Jerry's op in this thread, he has the checksum listed. If all else fails, redownload and reflash. Oh, make sure you aren't doing anything with your phone during the download. That greatly decreases the chance of a bad download. Or download on a pc then transfer the zip to your phone, thats what I always do.
There's your problem.
With the last three releases of your build I have been having an issue trying to get the V6 Supercharger and KAK scripts to stick. Or at least the scripts are saying they aren't sticking but are still showing up in the int.d folder. Any ideas?
