Root [ROM][WIP] BACKside ROM (CM7) + Green Machine Theme
Merry Christmas Jerry and all.
When texting you get words pop up.
My wife just told me after I was "playing" with her phone, she no longer gets them. Is there an easy fix for this?
Thanks
In the Keyboard settings, make sure the box is ticked for Show Suggestions.
The latest update completely borked my phone in like the eye. itll go through the bootup logo thing and then itll come on for like a second in the homescreen and then itll go right back out to the zippy fire circle. im gonna have to do a full wipe and then reflash, makes me sad cause i got complacenet and didnt do a good back up at all this time. just figured id say :D
I have a few issues.
1. Booting up, there's no sound "warning this phone etc etc". Not a huge issue but where did it go?
2. My time at the top is MIA. Any clue how to get it back?
3. Sometimes apps are crashing on me.
When you get a fresh download, before putting it on the sd card, check the md5 sum to make sure you didn't get a bad download. The other thing you will need to do is make sure you wipe data/factory reset,cache partition,dalvik cache(advanced section). Then in the mounts and storage section, format boot,data,cache,and system.
The ROM will not Bork your phone. A corrupt download, or residual data from an incomplete wipe, will.
1. That's been gone for a while, sadly. :/
2. Go into the Cyan settings and look for the clock options. I found that setting it to the middle and back to the side fixed it.
3. Only thing I can think of is your memory is getting bogged down from too many apps, or the app is too intensive. Words With Friends will crash on me every once in a while from too much effects.
Go to settings /cyanogenMod settings /interface/status bar tweaks/ clock color. Select and change color to something that will show up in status bar.
did a fresh install of the new build. Hadn't messed with themes or anything else yet. Clock color was set to '0' and wasn't showing up. Changed the color to white and it appeared.
thank you!!!
edit: just saw the post above me...thanks to you as well! This was making me soooo mad.
Out of curiosity, what does everyone recommend for cpu settings? I have it has 320 and 825 with interactive governor. Does restore on reboot matter?
A good starting point for the best battery off charger times and good performance with no system or app glitches or force closures is 768MHz max-480MHz min. Smartass 2
thank you!!!
You should never use restore on reboot until you've thoroughly tested it's stability. I recommend using your camera or perhaps the gallery as both are pretty cpu intensive. Start higher, as you already have, then test. If it reboots under load, you're running too high. Lower it by a notch, and try again. Once you can run the camera or gallery stably you've reached your sweet spot. That's when you set the restore at reboot option.
Every time I install a new build of BACKside right away I go in and uninstall Gallery.
Would be awesome if the QuickPic dev would allow Jerry to add it into BACKside so we can kill off this nasty default Gallery once and for all.
I don't intend to remove the default gallery app, it's a part of Android. You can always install quick pic, then go into manage applications and select the gallery, then clear defaults. You will be asked a few times when accessing images which you want to use, quick pic or the gallery, just check the default box and select quick pic, and it will become your image app. ;)
Removing the gallery altogether can bork other features/apps/functions that rely on it's intents.
alright this is an odd issure i relinstalled backside synced my jambox via bluetooth and the music player isnt understanding my artists only the songs bought on google music are recognising
I have been removing gallery from my phone since right after I rooted (early April) and have never run into a problem. Quickpic has always been there in place of gallery for everything. Hopefully that remains true.
