Rxpert83
Dr. Feelgood
fact reset wipes data, cache, and sd-ext if one exist. Where does dalvik reside???![]()
Right there in /data boss
:thumbup:
Also a last ditch effort to hear those pesky callers that dare to bother you while you try to tweak your new rom.
TAKE A TOOTHBRUSH TO THE SPEAKER GRILL AT THE TOP. DO NOT POKE IT WITH A PIN. DO NOT USE RUBBING ALCHOL.
So I just wanted to give everyone some ideas, I am still working on trying to get rid of echo but I've managed to increase overall system volume. I have deleted dsp and audio configuration file (of course I made backups) first reason for deleting audio configuration file is because we don't have radio hardware functions, there is no hi fi anything. Also there is multiple audio overlays in cm 10 that will not function with this phone. We don't need all those options in sound panel. Ie quiet hours, safe volume headset blah. I don't have time to go thru it all properly so a few apps did help namely equalizer by smart android apps and volume + and lvh v3.6 by Meltus get the full apk or your waisting your time. Now the eq works great system wide as a amp and lvh works good for increasing in call volume when using this make sure you pay attention you want the orange colum and the last one in that row hs+bt+icv 3 boost.
You can also edit the build prop file
Ro. Configuration. Vc_call_vol steps to 30 lol it honestly won't recognize past 20 I think but try it won't hurt it's the max volume setting abs you can adjust the default value as well so that way you can always start with a louder in call volume
v6 shouldnt be needed, but a nice work around for now. Reason most themes wont work is most are for hdpi+ which this display is not.For the best data connection make sure it says 1x @the Lil can you hear me now bars.
So in preferred network Mode settings check lte/cdma/evdo you will have 4g speeds. if it says 3g your getting the aohell experience lol how many of you know about that?
lte/cdma/evdo should be set by default.![]()
With metro thats normal lolI don't know if this issue has been stated. But the other day I flashed CM10 4-28 build with the modified build . prop and whenever I tried to call my friend it would dial then say "call connection lost" so I asked him to call me instead and it worked. Then afterwards I was able to call him without it losing call connection.
It did it like 5 times in a row though and instantly disconnected every time. This is also the first time this has ever happened to me and I've had my motion for about a year.
Edit: Maybe I've just been lucky up to this point lol
its not even been out for a year yet![]()
Hence the word "about" Haha I got it right when it came out but I don't remember when that was. So my bad lol
Was there an echo?
Backlight hasn't been fixed yet right? Or am I lagging?
hasn't been fixed but you can just double click power button after you turn screen off and it's on still. off-on-off = no backlight
