Yeah, I'm sticking to CM 10 (JB 4.1.2) for now until an OFFICIAL/FINALIZED/MASTERED Jellybean version of 4.2 is out and ready to flashed.
it may nvr be actually official, it may be possible to get it fully functional but it may also keep some bugs since we have a locked bootloader.
it's officially unofficialit will never be official while its locked and using 2nd-init.![]()
i couldn't get it to work at all. after i disable lockscreen in settings i had no lockscreen at all even though holo locker was enabled
locked and using 2nd-init shouldn't stop us from becoming an official device, the droid2, droid2 global, and defy are all supported devices, downloadable from get.cm, and they use 2nd-init because of a locked bootloader. I'm sure there's more those are just the devices I know for sure are officially supported and are locked.
those are popular highend devices, that were on GB irrc too, not a lowlend prepaid device.
They do have a program so unsupported devices can get official, they're just not supported by the CM team. Someone has to step up to maintain the device repo.![]()
I vote PG![]()
Of course lol it's Cm after all. Open up your settings and go to themes.
I just tried a bunch of themes they all worked perfectlyAlthough some are only supported on certain dpi
that's a bootloopQuestion? How long Does it take to boot? I loaded it up but it never passed the cyanagon mod logo. It just kept spinning. Any advice?
did u factory reset? is it the first boot? how long have u been waiting?
