Android?What!?
I tried this version, nothing seems like it doesn't work, the only thing is the low in call volume still. I like the recovery
didnt know mine every had a backlight issue???backlight issue seems to be gone
Works fine with me
check wifi.![]()
1st one didn't then second one did now this one doesn't have backlight issue
and hey if i used a rom that flashes version c modem. does that stay that way. do i need to do a kdz flash or something to change that or does flashing this rom change that?
How is your in call volume?
this just flashes system, nothing else, so everything else remains the same.![]()
Is the 4g icon seen in the new build? I don't know if someone answered this yet
Confirmed, did not totally solve the problem...the echo is less, but not totally gone.That fix doesn't work for everyone as I've already stated I had did this weeks ago and 1 out of 6 still had echo
I got boot loop after this. So don't click on wifi if you did the screen flashes and it reboots(the cyanogen mod boot loading animation was really laggy). I turned it off completely and hit power button and volume down and factory reset it.freezes and reboots when i try to start wifi but i can probably just swap wlan.ko from another rom
edit:didn't work
i still don't get why everybody is saying low call volume it sounds just fine to me. no more heavy metal for you guys.
cheers.any echo at all on this build? And no clue wtf happened to wifi!!!
I know lolYou broke it ;-)
No echo that I know of.
