Root [ROM][WIP]CM10.0.0.l0-BobZ
Alright here's what happened.
On the beta 4 build the build.prop mod doesn't fix the echo, makes it worse and you're super loud. I haven't tried after rebooting. Which someone should test for me. Because sometimes problems go away after rebooting when first flashing.
On bob's latest with the aboot, boot, and modem from beta 4 and modified build.prop. Backlight problem still there. So it's not the kernels that fixes it on beta 4. I'm guessing the problem is somewhere in the lib files.
4g speeds are like stock, it's smooth. Echo is gone and mic volume is perfect.
We have ourselves a 99% working cm10. Back light is not really a big deal.
I would like to think everyone here in the community that helped put this rom together. Especially Bob, Hk and PG for bringing it to us.
It's time to celebrate. :D
Now the handset volume is still low though even with pimp my ROM AMR wideband tweak..
I tried the new build prompt flash first. Still echo. Then I downloaded the updated ROM and did factory reset. Still had an echo. Idk but I'm using the other cm build from hroak13. Its working fine so far..
Is SMS and mms on HK b4 working wit the 4g fix and build prop fix and pgs MMS apk
Why cant i download 4/28 on mediafire. No matter what i do it only diwnloads 48.9 kb. Is there another site with chance of gettun the full ****** file
No need to curse, even masked profanity makes it much less likely that someone will go out of their way to help you.
Have you tried downloading it in a different browser?
Also, just to confirm, the issue is on your end. I'm downloading now in Chome version 26.0.1410.64 m
HELP okay I got the private barrel of wine :-P I have a few minor problems
1. Echo still there
2. Bluetooth MEDIA doesn't work only the phone call part
3. My in call volume is SUPER low I can barely hear on speaker phone and on the ear speaker
This is a bomb a#% ROM though !!!:
Yessir. Ive tried just about all of them. Opera, Boat, Maxthon..... I seem to be able to download all the other builds but not that one. Kinda strange.
