So far everything works great! Connect to Wi-Fi, no backlight glitch, and phone calls have no echo or sound problems.but. the only thing that this thing doesn't have that the lg motion 4g had on stock is 4g while on call. every time I call my data goes away and I can't access the internet. I'm usually not home so can't connect to Wi-Fi. Any fix for that?
WiFi does not work for me. Will not connect ever. Also whats the correct flashing order? Im doing modem C, cm10, gapps. Is this right?
Just flashed 5-21 and I noticed that it was using CWM 5 for LTE2, so I took all the files that relate to recovery from PG's 5-17 (which is CWM 6 for Vu2) and put them in a flashable zip: 2nd-init-Vu2.zip
EDIT: I forgot to mention that the backups made in CWM 6 differ from those made in CWM 5. CWM 6 makes a null .tar file and a .tar.a file with the actual data inside it. To convert your CWM 5 backup, add .a to the end of each .tar file and make a null .tar file for each. Then, add d41d8cd98f00b204e9800998ecf8427e to the nandroid.md5 for each null file. Or... I guess you could just make a new backup instead.... that works too :/
Cm10, gapps, then modem. But i suppose it doesn't matter much
Edit: actually, it might mater since flashing modem then cm10 will probably just delete the modem
I flashed from firmware c and flashed just the rom and gapps, no fixes or modems or anything, and the only problem I had was the phone would freeze constantly, almost any time I opened an app, and I had to pull the battery because it got ridiculously slow (2 minutes to get back to the launcher).
I don't think I did any data wipes/factory resets/etc. But everything else worked that I was able to test.
Bobz your last build has been working fine for me, the only and slightest problem is the sensor won't respond right and when you wanna hang up a call screens stays black and won't wake up. Other than that I value and thank you for the time you are putting into this.:thumbup:![]()
