Someone mind sharing the Pg MMS for me?
Me 2 pls![]()
Well I tried Adding pgs MMS to the 5-21 version and I still can't send MMS it stays on sending... anything I could try?
Did you change rename the original MMS.apk to .bak before moving the new apk into your system folder?
I flashed from the 4-22 ROM and I still got the backlight issue, I just did a data/factory reset wipe and re-flashed to see if an app was the problem.
EDIT: I can confirm it was not an app since after a clean wipe it still happens. Going back to 4-22 for now.
OK, maybe I missed something because I've been busy, but has a fix been made for call volume?
