Root [ROM][WIP]CM10.0.0.l0-BobZ
i noticed all the fm and hifi files are now gone from 5-21 build maybe that had something to do with call volume. ie: causing conflict or something.
I was on 4-22 then I factory reset in recovery, wiped Dalvik Cache, flashed Gapps, and then rebooted. Then I went back to recovery, wiped Dalvik, and flashed 4-28/Gapps. Then did the same again and flashed 5-21. I still have a backlight issue. Can someone just send me an apk or something that can fix it? Maybe an APK that flashes the new light configurations? I forgot the file extension but wasn't it like light.(something)?
You might try GPS conf from pg build because I think Bobz uses a European GPS.conf or something similar
On the train back from work at the moment for another 45 minutes at least and I happen to have pg's build on my sd. Will give it a try now and let you know how it goes. Luckily this train is not a subway, so I'll be able to test it too.
Didn't work. Arrgghh! I need gps!
Just want to say THANKS to all you guys for your hard work, BobZ, PG, and others. I tried a few of the previous builds, but just lasted a few minutes because of call issues and stuff. I flashed the latest 5/21 build and it is awesome. No more echo and volume was better. Now all that I need is gps and bluetooth to work in my truck. I even got themes working thanks to Jdgui Again, just to reiterate, AWESOME work guys. For now I'm going back to Collab 3.0.1, but I'll be back.
just an fyi if anyone needs to replace their phone or a dev wants to pick one up to join the cause, the motion is on sale for $49 at any metro store till the 30th.
That's for new customers (new phone numbers actually) only. That's what I heard.
Replacements cost $15 if you can wait a couple of days. Same day replacement costs $30.
If you had the phone for less than a month, they'll replace it for free and on the spot if they're in stock.
Can anyone point me in the direction to disable my proximity sensor completely? Can use dial pad or answer calls waiting sense screen goes black. Any help would be much appreciated.
The AnTuTu benchmark scores with this ROM...pretty nice :D
Would they replace a cracked screen for that price?
My friend is being charged 36 or 39 dollars to replace a phone with a cracked screen through his insurance policy. But they are having to get one from another store.
