Root [ROM][WIP]CM10.0.0.l0-BobZ
There's an app that I installed that caused the backlight issue. Because it was fine for the longest till I was installing apps then it started staying on. But I was installing apps 2 or 3 at a time so not sure which one caused it.
The backlight issue appeared one time for me too. But it went away as soon as I double pressed the sleep button. Weird.
Ive done this, even on my home wifi w/ "excellent" signal it will not ever connect.
:eek: is it possible something is wrong with the Wi-Fi radio? Have you reflashed firmware from sammyz unbrick method tried to connect WiFi then reflash cm?
Sent from my LG-MS770 using Tapatalk 2
I can't reflash anytime soon my laptop was stolen. We can't reflash from phone can we
Can't reboot to recovery morning call empty is what I get but I just held power button for about ten sec and let go it rebooted
This might be a very noobish question, but no shame over here: do you HAVE to do a factory reset if flashing over an older build (5/17 to be exact)? I just don't wanna have to go through all the hassle of getting all my settings right again if I don't have to. Very excited to try out the 5/21, just been busy with work all day still.
Everything is lovely about thus ROM < 3 I am still not content with the camera quality ..still looking for a fix
To use any CM theme you have to change your DPI to something other then 160 and change it back after you pick the theme (if you want)
Just search google play for something like dpi changer, change the dpi, reboot and apply theme
Yeah. I read a few days back that the DPI had to change, but themes worked for me on HK and the 042813 build without changing anything.
I know where and how to change it, but what is a good number to? 140?
Thanks.
Because Vibration doesn't work at the moment, and it is being worked on. In the mean time. I will help everyone out.
Click me!
It is only a patch till a full fix comes out. But for now, that should help you.
1: Install!
2: Open app!
3: Press menu key!
4: Select settings!
5: Set Settings as followed
----1: ViBe is always on!
----2: ViBe always for calls!
----3: Vibe always for sms!
----4: Default ViBe is 'Ramp Down'!
----5: ViBe during an ongoing call!
6: Reboot!
