Root [ROM][WIP]CM10.0.0.l0-BobZ
Yep :D
Call volume is still too low for me. I'm in my room with a decent amount of silence and my hamster running on his wheel is enough to eclipse the sound from voice mail for example.
Other than that and the 1x at the top this ROM is already too awesome.
My call volume is fine .. TV and fan are on and i could hear my calls clearly
is it stable enough to use everyday outside the calling situation? i dont really talk much (on a cell i kno) but i do text/mms/use data alot and i would LOVE an updated google now
I'm sure everyone will agree is more than stable... just a few hiccups.
Call volume is still really low Maybe its just me but signal strength is bad. In my house usually have three to four bars and now I have none to one bar flashed from detoxed f.
What are you guys doing to get rid of echo, I simply keep getting complaints of echo, still can't usb tether havn't tested surf and talk ye. Hotspot pulls speeds higher than phone, 7mbps down but 14-16 down on desktop
Just Flashed 05-21-13, along with the version c modem. Works great. No backlight issue, better call volume, smooth as butter, music works, and no echo. :)
All speed tests were done with two bars of service, inside.
was that 3 am?
Another thing I noticed was the apps in the app drawer cut off half the name
and my speeds
On 5 21 13.
Can't hear text notifications.
Tried on the SMS app. Pinger and GoSms. Any fix for that?
Edit. Never mind. Rebooted and its back. Idk why it wasn't earlier.
Also it boots into airplane mode.
Other than that and echo, its pretty cool.
Edit#2: found a difference in the last build prop and this one, under audio, this line is present in the 052113 build:
ro.qc.sdk.audio.fluencetype=fluence
Idk what its for, but when I deleted it, and rebooted, the echo was gone. Lol.
I wouldn't advise doing the same until I know what its for. X.x
All mine have the names none are cut off
For some reason backlight is staying on for me. I'm going to go to stock and then flash
Mine goes off when it should.
I flashed from stock d, I believe.
Probably going back to stock.. so far cm has been nice, but there are still a few bugs that need to be tweaked.
There's an app that I installed that caused the backlight issue. Because it was fine for the longest till I was installing apps then it started staying on. But I was installing apps 2 or 3 at a time so not sure which one caused it.
HELP!!! EVERY link for the 5/21 version is not working it says downloading but only downloads a few KB every time please tell me what to do these bugs are killing me
