Root [ROM][WIP]CM10.0.0.l0-BobZ
Angablade just gave me a test build that has near EVERYTHING FIXED
Only things that aren't working are
Front facing camera video
Phone won't vibrate when being called
and just the 1x icon is still there
But EVERY other issue is now fixed, low call volume, a LOT louder :)
this is near perfect.
What about GPS? Does it lock on with no problems?
Hey guys, does anyone know how to install any of the apps from Pimp My Rom on this build? Worked just fine for me on earlier builds. I have flashables of the others I want I was just wondering if anyone has one of Pimp My beats? Thanks
On bobz new build everything is working perfect except for GPS navigation and 1080p camera is magenta (I record 720p anyways). Last time I fixed the magenta camera by unrooting and flashing from stock D so I might do that tomorrow. Also little bugs have been fixed that bothered me before. This is sooooo good. :D will give more feedback as time goes on.
So far sensor is working much better, and it looks like in call volume is fixed :D. Backlight is also fine now.
Yea in call volume is indeed a little more bearable, but I still can't turn it up or down. Even with the slider
Go into settings and go into sound settings and make sure every single slider is completely to the right. Some times there are other volumes that go un noticed and may affect others.
Just Flashed 05-21-13, along with the version c modem. Works great. No backlight issue, better call volume, smooth as butter, music works, and no echo. :)
All speed tests were done with two bars of service, inside.
Looks like we are not far from a fully working 100% build:D
Yep :D
Call volume is still too low for me. I'm in my room with a decent amount of silence and my hamster running on his wheel is enough to eclipse the sound from voice mail for example.
Other than that and the 1x at the top this ROM is already too awesome.
