Root [ROM][WIP]CM10.0.0.l0-BobZ
This ROM is pretty beast. I really like it, and thank you for making it :)
I'll list some observations:
- I love the layout of messaging, it looks sick!
- The phone overall seems way smoother and slicker and faster by default
- I just flashed it, so I can't 100% quote on the battery, but it doesn't drop 1% every second unlike stock, so that's pretty good
- Apollo is way better than the stock music player, and my headphones sound louder now too :D
Have no issues with it none so ever, all the google apps are fine, WiFi connects. It's been all good so far.
Thanks again for this ROM ^__^
You ever find any bugs yet
And did u flash bobz cm10 over stock firmware F ?
The only bug that I when I put this on my brothers phone is the mic volume when using Skype is really low, but other then that its a great ROM. Thank you. (it happened on both builds, and I flashed from f and c )
Internet calls freezes the phone. I used GrooV Ip and the phone's sip account on the phone app both have had the same effect.
I wonder would this fix MMS in cm10
http://www.talkandroid.com/guides/misc/how-to-install-the-cyanogenmod-10-1-mms-application-on-any-android-4-1-rom-includes-emoji-and-quick-reply-functionality/
Anyone know how to fix the camera? Every time I try to snapchat my phone just freezes and sometimes it works but the camera looks weird. Can't record at full HD either.
Well It looks like I will be Reflashing this weekend, unless anyone has a flashable zip of the original camera that came with this rom
The JB camera I flashed sure it lets me save to sd
But i have to exit to home screen after every picture or else i cannot take another
You could just download the app from the rom and move it to your system/app and change permissions...
Learn to do that for future reference, but for now, here you go.
Try GPS status and toolbox App and reset GPS. Also alot of phones seem to like opening GPS and getting a lock in stock rom then reboot into recovery with lock on and flash cm.
Is anyone else noticing that when muti-selecting anything the blue bar at the top isn't pure blue? The bar is split in to two colors if that makes sense to anybody. Just thought I'd point it out because on the Nexus 7 (aka pure android) it doesn't look like that.
Where's the MMS file?
Get a copy of pg's 5/17 build zip. Open/extract it, go to system/app/mms.apk (remove your old mms.apk or just rename the extension) then move it to your system/app folder. Make sure the permissions are the same as the old mms.apk on your phone. Reboot when done.
There's a dl link of pg's mms.apk by itself somewhere on this thread if you want to make it easier.
