SwoRNLeaDejZ
Android Expert
Just installed the ROM, everything is working great -- pic messages, 4g speeds, not having any of the commonly reported issues except that I can't access my external sd card from in CM10. I see my data when I explore from the computer, but ES file explorer shows it as empty, and the built in CM file explorer refuses to open it and says I need elevated permissions, though as far as I can tell I have root access. Do I need to reroot the phone after installing Cyanogen, or can someone help me figure out what's going on here?
also holding the power button doesnt give me the option to reboot to recovery, only power down, change profile, reboot, and airplane mode.
edit:
I installed a different SuperUser to /system and now ES explorer shows me as having 2 external sd cards, 0 and 1. 1 Is mine with my data still on it, and the other shows as empty and is the phones internal storage.
Go into the CM file manager, bottom right hand side there is a thing that looks like a bookmark with a star in the middle, tap it, when it opens, sdcard0 is internal, sdcard1 is external. I had the same problem. If you go into external_sd it will show as empty, you have to do it the other way.
